My Attempt : Refurbishing 3 Piece Work Rims
I had been looking for a couple years for an ideal set of rims and
with some patience i finally found a set of pearl white VS-XX rims 18X10 +22
for my R34 GTR .
When they arrived from interstate they were in poor condition , 2 rims the lips had been buckled with water marks , all rims had severe scaring and inner barrells pitted from worn brakes and faces had major stone chips . Damn !!!!!
I had never attempted this before to this extent so i started off with a 12 point socket with extension bar and pulled all the assembly bolts apart one by one = 160 in total ………. some of the bolt heads damaged from previous owner and had to be cut off with grinder - 10 in total . Purchased 10 new bolts from WORK U.S.A
in California $50 delivered , Work Aust could only sell in 40 bolts lots for $165 I LOL'D
Presto the faces popped out quite easily
Heres the before pic : Note how black and farked the barrel is !!!! :yucky:
Before i powder coated the faces i numbered and marked each centre with a hacksaw blade to match every barrel and taped the hub face and inner lip of the centre that slots back into the barrel ----basically the the back part the assembly bolts go through .
If you get powder coat on the above sections of the centre face the wheel will NOT run straight , this should remain bare metal .
I got the faces powder coated in satin black (original colour) the guy from HWH Powdercoaters - Oleg and i discovered underneath the Pearl White was Green and then Black …. lol . So it was taken back to bare with sand blasting, lots of work with VS-XX pattern .
Cost $90 each wheel for sandblast and Powder coat
Powdercoat pic :
img2149x.jpgmark vidmar
Had the buckles taken out of the lips and polished with sanding paper 400 -600-1000-2000 this removed pits in the lip and water marks for final finish run over with mothers aluminium polish and power cone SHINY
Shinyness Pic :
The inside Barrels i spent several weeks trying to clean the pitted and brake dust stained aluminium barrel with sand paper but changed over to a nylon grinding wheel which eventually did the job this with a chisel cleaned the led weight stickers off and Work manufacturers stickers off - as these were pretty damaged = Farked
Barrel cleaning pic :
After barrels cleaned i painted barrels with aluminium etching paint and high temperature paint 3 coats , came up ok
Pic of inner barrel painted :
Next was to polish the centre caps , these had a blemish surface so i used Autosol , Meguires plastX with my DA polisher in a vice , also polished each assembly bolt separately with Autosol .
Pic before and after :
I bought a torque wrench with some medium hold thread locker and began the tedious job of bolting the faces back to the barrels , started bolting at 6 o'clock ,
12 o'clock , 3 then 9 respectively so on and so on all the way around .
Torque settings are 18 lb ft for a 7mm bolt
Pics completed :
Uimg2175jr.jpg[
:rolleyes:
Hopefully my experiences can help someone else on this forum who is thinking of refurbishing their rims as well ……... :D
Original price for Rims $ 1800 after work spent $600
Also bought some Work Royal Lock Nuts
Will post pics on car !1
Edited by NISSAN GTR
awesome result, chuck up some photos once they're on the car!
Also fyi, work royals appear to be the same as the mcgard splinedrives which can be had very cheaply via amazon.com
Cheers everyone for the positive comments .
Happy seal , i also was deciding if powder coating/anodising the lip was such a good idea
sure it looks great but if you get some rash , then what ?
I so want to see your pics , any questions happy to help ....... :D
^^ Will do. . .won't be getting home until Friday evening though. . .so sometime next weekend I'll post progress pics. . .
Didn't find a pic of the matte bronze centers with polished barrels. . .looks pretty good imo. . .
  • 3 weeks later...
Looks awesome! I hope mine come out looking as good!
Start. . .
After a few minutes of buffing. . .Works well!
Putting all the disks together so they can get cleaned. . .ordering some hardware from Work and picking up some paint tomorrow!
Wow they need some T.L.C Nice Work !!!!!!
Its surprising how well that little red disk works in the barrel , i had to use a chisel and remove wheel weight stickers and work stickers off
Earlier i dont think i mentioned using grease and wax remover as a last step for prepping to paint ,
this is pretty important with aluminium .
  • 2 months later...
I am looking at doing the same to my Nismo LMGT2s. When you bolt in the centre, will it automatically sit concentric due to the location of the bolts?? Or do you need to make adjustments to get the centre section concentric??
Mine slotted together fine wihout any adjustment , i basically put them in the exact position they came apart
I made notches with a hacksaw blade and numbered the back of each barrel and face position 1-4 on the back .
Also most important do not paint any part of the centre face that meets the lip of the barrel = your in BIG trouble
otherwise go for it !
I want to see pics please .
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
