To keep it simple I will just start another topic with what I still have for sale and some pics:
Splitfires to suit RB20, RB25 and I think RB26? great condition - $400
Trust Greddy type R blow off valve - $200
Alloy 52mm radiator with stock fan and shroud, bargain at $150
Hybrid intercooler with some piping - $200
Apexi Pod $50
Red wheel nuts. Have paint flaking off here and there, but make a very cheap lock nut for your wheels $20
Nismo gear knob - $60
Gab height and damper adjustable Coilovers $600
Adjustable Rear upper Arms. One has been repaired after it snapped about 3 years ago. Have not had any issues since. $60 pair
R33 front callipers, rotors and pads and rear r32 brakes (think they are same size as 33's) - $350
Front Strut brace - $80
RB25 Gearbox and Cusco Single Plate clutch $1500
R32 GTR front bar with N1 vents - $600
R32 GTR bonnet with Aerocatch pins $500
R32 GTR front reo - $400
Bride Recliner Drivers seat with bride rail to suit r32 33 and 34 - $400
R32 Gtr passenger seat - $200
R32 spoilerless boot - $200
R32 non rolling Shell. Is still registered, but obviously sold de-registered and will come with mod plates for rb25 conversion, gearbox, cage and turbo. Will take offers depending on what's left on the shell. At this stage this includes brand new clutch master and slave cylinders, big dry cell battery in the boot, in cabin kill switch, boot kill switch and doesn't include any of the bits for sale on here
pair of s15 rims with legal thread. gutter rash on both rims, and one may have a slow leak puncture, as it has gone flat $80
Advan 18x9.5 +22 and +38 with minimal tread. One of these has been repaired a few weeks ago for a crack in the rim. No issues $600
S1 3P Workmeister 18x10 +30 with 225's and 235's. Have very light rash on all four rims $2200
https://www.sau.com.au/forums/topic/406809-wrecking-my-modified-r32-gtst/
some pics as promised and some added stuff
rear seatbelts for sale
front indicators. one perfect, the other has one broken tab as can be seen in the photos $50
oil cooler and remote filter kit. came of a r33 and has been sitting in my shed for the last 2 years - $200
Stock intake and turbo manifold
s15 rims - $80
space saver - $20
Hi mate,
I am looking for $1000 for rolling shell, with stock suspension, stock front seats and steering wheel and no brakes, bonnet, front bumper, dash
and byo wheels
I can take some pics tomorrow, or you can come have a look if you want.
Edited by PWND
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
