Hey there guys,
Just wanted advice on performance on a r33 gtst 4 door automatic that i have just brought.
What the car has:
rb25det engine 230,000 km's
3inch turbo back.
Cold Air intake. (K&N pod with heat shield)
Yellow top Coils.
Hybrid frount mount intercooler.
Solenid been removed.
All done by previous owner.
took out the back (private) road on the gtech. ran 0-100km/h 6.1secs and 1/4 mile in 14.3secs @ 159km/h
almost stock times for a automatic from the research i have done.
What i have done so far is installed a turbosmart boost tee turned up half a turn and install a boost gauge.
I haven't had a chance to re gtech it but feels a tad quicker.
Just need some advice on what to do next, without changing turbo etc.
Walbro fuel pump? - heard they run quiest and are a direct replacement without rewiring.
ecu? - read or heard you need to put a r32 or r34 ecu in to be able to tune it. looking at nistune.
What my goal is, is to be able to alteast run into the mid 13's and atleast keep up with my modded Ford XR6T.
this car my have some history on here and someone on the forums may have owned it, the previous owner gave me the bullshit story the old
owner was a girl that never drove it hard.
The reason that i say this is the passanger side front door has been buffed but i can still faintly see a skylines australia sticker that was on the car.
the car is a 1993 r33gts25t silver with r34 wheels on it.
Thanks in advance.
Edited by tacticz
Is your car an Auto? Is see mention of Auto times there.
a Z32 300ZX or R32 Rb20 ECU + Rpm window switch for NVCS is what you need for Nistune/
Mid 13's is possible on sticky tyres and the standard turbo with a tune
I ran a 13.9 with a crap 2.1sec 60ft in my 33 coupe back in the day, I had a front mount, PowerFC and a 3" front pipe back exhaust
Yes it's a automatic. I'm actually surprised that it's hard to achieve good times with lots of work to these cars, never been a skyline fan
but the car was cheap at 3k so i had to have it, and loving the handling of it compared to my XR6T.
I know the falcon is 4L but intercooler, CAI, injectors, pump and tune can see 380rwkw for a much heavier car jumps into the 12s easy.
I think i need to move away from comparing em.
oh reary? Do you know of anyone who's able to tune standard r33 auto ecus in sa? otherwise it'll be an auto z32 tune for me
Only me in Australia but its not difficult.(very popular in Japan)
Just need tools.
Tools is R33 ecu daughter board (made in Japan), emulator , programmer, programmer adapter , chip and Nistune software.
http://www.skylinesa...__fromsearch__1
Z32 R32 ECU can not use R33 auto.
Just need tools.
I'm in Adelaide, so to change the daughter board and dyno tune it would be $580? so all i'll need is to get a bigger fuel pump. might be worth the drive to you to get it done.
Also with the turbo internals, I have 1993 i assume it's a series 1 do they have the ceramic fins or metal ones?
Edited by tacticz
$580 is just basic dyno tune.
If you would like to full tune (road and dyno both tune) $700.
If you or me find 3 people in SA I can come to you.
Series 1 turbo is ceramic and metal.
Series 2 turbo is ceramic and plastic.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
