Bringing back an old topic, I don't think highway patrol care about 'poke' as long as the wheel is sitting pretty much in the guard
Two officers checked my car yesterday after they pulled me over for a random check and said nothing about my stretch or poke.
However it may depend on the police officers too.
735041 413290632084687 2387347 N
while its nice to have deep dish, flushed wheels... wheels that stick out, IMO look weird.
btw anyone knows what a good offset for 19x9.5jj wheels to be on the BNR34?
also, if the overall diameter of the wheel + tire is close to stock...is it legal?
[quoted from VicRoads here]
"The overall diameter of any replacement rim and tyre must not be:
-more than 15mm greater than the largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series, or
-more than 15mm less than the smallest diameter tyre specified by the vehicle manufacturer for that model or vehicle series"
thanks for clearing that up =)
+12
i think it was said a few pages back, but that might be the 'increased track' rule,
But Rims and tyres must also not "foul any part of the body, suspension, steering or brake components; at any position of suspension travel, steering movement and when in the straight ahead position"
[Keep in mind, this is coming from the Victorian Vehicle Standards Information]
Edited by alex182
i'd imagine as long as the tops of the guards don't foul the tyres it'd be ok. as long as you're not running ridiculous amounts of camber.
Lots of cars have bumpers that narrow inwards
Stanced cars have always looked broken to me. Especially from the rear, and I dont see the point of fitting massively wide wheels only to camber them in just to fit the tyre into the top of the guard
With that amount of camber and lack of rubber on the road, stiff suspension and crappy tyres (in most cases) braking performance goes down the toilet
Edited by junkie
  • Like 1
Yeah, plenty of these cars you see around are just funny to watch. thanks to the stupidly stiff suspension they bounce around worse than a vn commodore that's sitting on the bump stops.
People seem to think that stiff coilovers are going to make the car handle like it's on rails. This might be the case if you drive around on a big sheet of glass, but in most roads a car with stock suspension will out perform a car that bounces around all over the place
^^yep, couldnt agree more, when i got my 32gtst the f*kn thing was stupidly low on stiff springs, whilst it looked the goods it skipped/bounced over every bump on the road, i returned it too standard and it was a LOT more pleasant to drive
I beg to differ, my coilied 34 handled so so so so so much better than my stock 34
what spring rates did you have? i bet they weren't 11 or 12kg springs like what some people put in. ones like the tiens only have about 8kg springs and will actually ride well. i had some unknown rate coil overs put in the front of my 180sx when i still had it. they were in there for 3 days before i pulled them out and put the old shocks with the old lowered springs back in. i went around a corner near home at 40kmh and started to bounce onto the wrong side of the road. i could normally take it at about 60kmh and be on the verge of losing traction.
thanks for the pic alex182 :)
the "poke" look, looks so wrong and possibly dangerous.
mad082: I think its not just stiff springs that causes it. I believe the phenomenon is bump steer...and it could also be due to the insufficient suspension travel that would cause the car to bounce. I had the Tein superdrift in my 180sx with hardness setting to slight more than half. I have also tried with the max hardness setting... high speed sprints (~220km/h) and corners (~90km/h) were fantastic. car was really planted to the ground and traction was amazing...but of course proper camber and toe in are required as well...
Tein Superdrift spring rates are 10kg front and 12kg rear if i rem correctly.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
