Bringing back an old topic, I don't think highway patrol care about 'poke' as long as the wheel is sitting pretty much in the guard
Two officers checked my car yesterday after they pulled me over for a random check and said nothing about my stretch or poke.
However it may depend on the police officers too.
735041 413290632084687 2387347 N
while its nice to have deep dish, flushed wheels... wheels that stick out, IMO look weird.
btw anyone knows what a good offset for 19x9.5jj wheels to be on the BNR34?
also, if the overall diameter of the wheel + tire is close to stock...is it legal?
[quoted from VicRoads here]
"The overall diameter of any replacement rim and tyre must not be:
-more than 15mm greater than the largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series, or
-more than 15mm less than the smallest diameter tyre specified by the vehicle manufacturer for that model or vehicle series"
thanks for clearing that up =)
+12
i think it was said a few pages back, but that might be the 'increased track' rule,
But Rims and tyres must also not "foul any part of the body, suspension, steering or brake components; at any position of suspension travel, steering movement and when in the straight ahead position"
[Keep in mind, this is coming from the Victorian Vehicle Standards Information]
Edited by alex182
i'd imagine as long as the tops of the guards don't foul the tyres it'd be ok. as long as you're not running ridiculous amounts of camber.
Lots of cars have bumpers that narrow inwards
Stanced cars have always looked broken to me. Especially from the rear, and I dont see the point of fitting massively wide wheels only to camber them in just to fit the tyre into the top of the guard
With that amount of camber and lack of rubber on the road, stiff suspension and crappy tyres (in most cases) braking performance goes down the toilet
Edited by junkie
  • Like 1
Yeah, plenty of these cars you see around are just funny to watch. thanks to the stupidly stiff suspension they bounce around worse than a vn commodore that's sitting on the bump stops.
People seem to think that stiff coilovers are going to make the car handle like it's on rails. This might be the case if you drive around on a big sheet of glass, but in most roads a car with stock suspension will out perform a car that bounces around all over the place
^^yep, couldnt agree more, when i got my 32gtst the f*kn thing was stupidly low on stiff springs, whilst it looked the goods it skipped/bounced over every bump on the road, i returned it too standard and it was a LOT more pleasant to drive
I beg to differ, my coilied 34 handled so so so so so much better than my stock 34
what spring rates did you have? i bet they weren't 11 or 12kg springs like what some people put in. ones like the tiens only have about 8kg springs and will actually ride well. i had some unknown rate coil overs put in the front of my 180sx when i still had it. they were in there for 3 days before i pulled them out and put the old shocks with the old lowered springs back in. i went around a corner near home at 40kmh and started to bounce onto the wrong side of the road. i could normally take it at about 60kmh and be on the verge of losing traction.
thanks for the pic alex182 :)
the "poke" look, looks so wrong and possibly dangerous.
mad082: I think its not just stiff springs that causes it. I believe the phenomenon is bump steer...and it could also be due to the insufficient suspension travel that would cause the car to bounce. I had the Tein superdrift in my 180sx with hardness setting to slight more than half. I have also tried with the max hardness setting... high speed sprints (~220km/h) and corners (~90km/h) were fantastic. car was really planted to the ground and traction was amazing...but of course proper camber and toe in are required as well...
Tein Superdrift spring rates are 10kg front and 12kg rear if i rem correctly.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
