Recently my 25det neo engine in the 34 has decided to make a very healthy knock noise!
In the attached video clip I have 1st put a pool noodle to the timing cover which has enhanced the sound, then 2nd onto the exhaust side rocker cover which sounds like normal tappet noise, so the knocking is either coming from the belt area or worse it is resonating up through the block.
Any ideas? Big-end bearing/timing belt bearing/worse?
Cheers All.
timing cover then rocker cover.wmv
https://www.sau.com.au/forums/topic/406836-knock-knock/
Last change penrite 10's racing 10w-40 full synthetic + 1/2 qrt of lucas, before that it was motul 300v
145,000kms btw on the clock, compression is very healthy/engine is still very strong and responsive.
Hoping it is timing belt, loose/slapping/timing bearing that needs replacement, but after listening to a load of youtube vids I am thinking rod knock :angry:
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6485196
You could just replace the bearings , i mean , it won't last forever and is by no means a permanent fix , but it would get you out of trouble for Atleast 6 months (providing there is no crank or con rod damage ) . ~$50 and a good day of work for someone mechanically minded
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6485282
Yep Motul all the way from now on!
I am lucky enough to have another nice 34 to drive atm, will be looking to pull down my 26/30 proj engine that has been sitting for almost a year now and try and do all the work myself/save coin, bottom end needs a rebuild, does not look to be too hard a job once the machining has been done, and there is so much info round here I am sure I can do it with patience and learn along the way.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6487304
Nah not at all eh JEZ, that engine is stock and so healthy across all cycls that is why I was not worried about the high kms, was looking to just put a bolton package in there as it is the weekend/cruiser, just bad luck I guess or previous history has now caught up.
Still deciding if a RIPs 30 bottom end delivered would work out better than rebuilding the current patrol 3ltr bottom end, would just need a better oil pump and be machined/bored/honed to accept forgies. RIPs stay with stock internals and do some crank work, but they are good for 600 ponies.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6487574
  • 3 weeks later...
Right O!
I have finally located the the source of the issue, the knocking sound is the CAS arm that enters into the exhaust cam shaft area, it appears to have too much play/wobble in there and the effect is a vibration/knock sound inside the chamber, this has resulted in what so sounded like rod knock resonating from the block up!
So on to resolve the issue - replace the CAS unit (expensive as all hell from Nissan) or further diagnosis and pull off the rockers and inspect the cam shaft and barrell area? I wouldn't expect this part to be the issue/worn out as it is forged steel.
Anyone out there know if this is a common worn out part issue for a CAS unit or has come across?
Cheers All.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513355
Mine did the same, the damage with mine was mainly the nose of the cam, and the CAS to a lesser degree. The damage to cam is pretty obvious, if you look in the front of it the teeth should be square, and 1+mm across the top. Just Jap had the CAS second hand in good condition, the cam I just bought second hand off here
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513398
I had to strip some parts from the 26/30 today and use the aluminium bracket from the 26 head gear that the CAS is mounted to , on the 34 it was fractured and only being held in place by the CAS bolts to the timing cover, now the CAS has no play whatsoever all fixed, but the knocking is now very clear and coming from the front of the exhaust cam shaft, so perhaps the same issue you had IPLEN and it has been worn away, I guess it is a pretty inexpesive exercise to swap a factory exhaust cam in there and see if the problem goes away, it should not cause any dramas if I leave it as is, but I want rid of that knock noise that is only there on idle, when on accelaration it goes away and then comes back on decel to idle, very noticeable at idle.
Check out the fractured bracket, it is just cast aluminium not very strong, and I am not sure what caused it to break just recently either!
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513669
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
