I have installed a Blitz oil temperature gauge but have no idea what is the right range of temperatures I should be safely running at.
It seems to normally sit around the 90 - 100 mark, but has gone as high as 110 on the gauge.
I assuming these ranges are all OK, but at what temp should I be getting worried?
I am running Motul Turbolite.
https://www.sau.com.au/forums/topic/406848-oil-temperature-question/
While driving around town mine tends to sit between 92 and 105 depending on how hard i drive.
If your oil temp is reaching 110 effortlessly then i would be concerned
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
