hi guys
i know the bosch fuel pumps are great like 910, 040, 044 being more expensve in that order etc
but does anyone have any experience with their fuel regs? they are rising rate like the malpassi ones you can buy, and i know the SARD fuel regs are even better, but how about the bosch ones?
i saw on a site the following 2 are available:
Rising Rate Regulator, EFI Push On, 1:1 $ 149.00
Rising Rate Regulator, EFI High Rate, 1:1.8 $ 165.00
im sure people can get better prices than those, but even those prices arent that bad.
i will be getting a BOSCH 040 pump, and theres a thread going on at the S.A forums part that people can get these intank pumps for $240! so thats real good.
any help would be greatly appreciated!
-Michael
https://www.sau.com.au/forums/topic/40686-bosch-fuel-pumps-bosch-fuel-regs/
I'm a little confused about the whole aftermarket regulator thing?
I understand that it is a bit of a band aid option for those not willing to go as far as injectors, many people seem to be getting a 2530, larger pump and a fuel reg.
Seeing as though I'm looking to get that setup and around 230-250rwkw, what regulator will be needed? e.g. rising rate?...
exactly what im look at getting at the wheels too, prob more on the 230rwkw though as my turbo is only hi-flowed /w bigger wheels from garett (kinda like t3/4 combo wheels) and turbo is now steel not ceramic
ive searched throughout the forums on this topic, and ive come up with the conclusion that although the fuel reg is a type of band aid option, its the only option in order to get some more out of your injectors if you dont have money to upgrade to larger ones. you would need the bigger pump to go with your reg though as they seem to go hand in hand.
i spoke with unigroup engineering who did the dyno on my car, they said if you can afford it, better to get bigger pump and injectors OR if cant afford that option then get bigger pump and fuel reg. in either case however, the bigger pump is a must.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
