Hey all
I have a R33 GTR and a set of work XD9s 18 x 10 +18. the biggest widest and smallest offset XD9s you can get. But they are a bit to sunken for my liking.
I'm thinking of running spacers to make it flush.
But can you run staggered size spacers front to back? I know the tyre / running diameter must be the same, but can you stagger spacers?
As the rear could use a 10mm but the front could go 15mm to maybe 20mm?
Also can someone recommend good quality, safest spacers avaliable?
Thanks
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/
i know what your saying, I've given up on offset on my R33 gtr , did have 10mm spaces just on the back, and didn't upset anything.
Don't think I'd go as far 20mm unless your going a bolt on, thats a lot of thread to lose in your wheel nut..
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/#findComment-6484157
dont be rude or anything, but what makes them so good?
There tired and tested brands....That are bolt on and not ebay/backyards jobs.
www.google.com - penly of reviews to read through just for peice of mind
Edited by sydking
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/#findComment-6484981
funny someone said ebay,
http://www.ebay.com.au/itm/NEOTECH-NISSAN-5-Stud-114-3-20mm-Bolt-Wheel-Spacers-/140822782086?pt=AU_Car_Parts_Accessories&hash=item20c9b12086
these are the ones I ran front and back on my R34 GTR V-SPEC II for 3 trackdays and nearly 10 months without an issue and they still look as good as the day I got them
only rolling diameter will upset the 4WD system, so you will be ok, ONLY GET BOLTON SPACERS and make sure they a torqued on propely
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/#findComment-6485441
http://www.ebay.com....=item20c9b12086
any idea on the torque specs used? same as the stock lug nugs need?
When i was looking into spacers, Alot were sugesting its the speed of ratation that helps keep the wheels from falling off, Not soley on the nuts. Not sure in the truth in that.
Though, Tourqe the spacers, go for a drive, See if anything has come loose, then id be checking a week later or so just for peice of mind!!
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/#findComment-6486009
any idea on the torque specs used? same as the stock lug nugs need? Yeah torque them to factory settings or a touch tighter, I can't remember the setting of hand but it is mentioned back a few posts
When i was looking into spacers, Alot were sugesting its the speed of ratation that helps keep the wheels from falling off, Not soley on the nuts. Not sure in the truth in that. there is some truth to this, but as wheels rotate in a different direction from side to side that would suggest that one side would tighten and the other would untighten, on my last truck it had right and left hand threads, one for each side for this reason, my current truck does not
Though, Torque the spacers, go for a drive, See if anything has come loose, then id be checking a week later or so just for piece of mind!! exactly what I was going to say
always use bolt on spacers not slip on, reason is then there is only one slip point ( the flat surface where hub and wheel meet ) the each set of studs have to secure not two
https://www.sau.com.au/forums/topic/406862-gtr-and-spacers/#findComment-6486879
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
