R34 GTT Four door Stripped parts
(SHELL IS GONE)
R34gtt Front seats -$200 with rails
R34 GTR fuel pump with cradle -$150
R34 dash -$100
clutster -$100
climate control -$125
center console -$100
glovebox-$25
Air bag steering wheel-$100
auto shifter-$5
a/c centre vents -$70
a/c side vents -$30 each
door trims -$50 each
window switches $20 each
hood lining -$50
sun visors -$15 each
(heaps of other plastics just inquire if you want something)
R34GTT RB25det NEO 137,000kms motor complete minus turbo -$1500
R34GTT computer loom complete-$150
R34 Highflow turbo -$800
R34 auto triptronic gearbox flex plate converter etc-$300
cross member-$100
steering rack-$150
castor rods with ajustible bushes $100
GTT brakes calipers front and rear slotted rotors front (near new) stock rear $900
Front hubs and knuckes $150 each
Rear hubs -$100 each
lower control arms $80 each
rear cradle with hicas-$100
rear camber arms $25 each
rear toe arms $25 each
Front upper arms $25 each
Reinhard jap made 3" ENR34 SS exhaust with cannon good condition sounds great-$400
R33 GTR radiator with twin thermo fans-$100
AU falcon twin thermo fan setup-$50
R34GTT doors complete-$100 each
Front bar (cut for intercooler) $150
R34GTT/R33 GTR Ohlins Coilovers-$900
Blitz SUS stainless POD filter ok condition-$50 with AFM adapter
R34 tripple guages with autometer smoked volts oil pressure water temp $150
Clear side inticators-$25
BM44 brake master cyclinder with brake booster-$200
18x8.5 18x9.5 Starcorp impuls with tyres-$800
17x9 +22 x4 Sparco light weight wheels-$800
PM for any more info etc everything located in Newcastle
0422646961
Chasing the stereo surround that goes around the din and below the AC controls
AND
The lower dash section between the gear surround and the top of the dash where the gauge cluster is
Must be good condition and need both sent to Adelaide 5067 please
AND
Both items $100 shipped
Hey I'm after the plastic bit under the ash tray and the rear? Thanks
Price listed centre console plastic $100
Hi mate,
What condition are the coilovers in? And just confirming they fit 1999 GTT? Don't happen to know the spring rates off the top of your head do you?
Cheers,
Shazza
Edited by XS80ST
hey shazza... thry were great when thry were in my car handled nicely all dampeners worked fine... not sure on spring rates i belive the part no was nis 10m ? i think i can confirm later if u want ? and yes came from a 98 gtt so thry will fit
Hey, I was just wondering if you are selling the interior door pannels? Also is the steering wheel still in good condition or has the leather started to go on it?
aircon condenser?
yes $100
door cards price is listed $50 each wheel is in pretty good nick
Can you get a picture of the steering wheel without that cover please?
Cheers
posting a pic now
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
