R34 GTT Four door Stripped parts
(SHELL IS GONE)
R34gtt Front seats -$200 with rails
R34 GTR fuel pump with cradle -$150
R34 dash -$100
clutster -$100
climate control -$125
center console -$100
glovebox-$25
Air bag steering wheel-$100
auto shifter-$5
a/c centre vents -$70
a/c side vents -$30 each
door trims -$50 each
window switches $20 each
hood lining -$50
sun visors -$15 each
(heaps of other plastics just inquire if you want something)
R34GTT RB25det NEO 137,000kms motor complete minus turbo -$1500
R34GTT computer loom complete-$150
R34 Highflow turbo -$800
R34 auto triptronic gearbox flex plate converter etc-$300
cross member-$100
steering rack-$150
castor rods with ajustible bushes $100
GTT brakes calipers front and rear slotted rotors front (near new) stock rear $900
Front hubs and knuckes $150 each
Rear hubs -$100 each
lower control arms $80 each
rear cradle with hicas-$100
rear camber arms $25 each
rear toe arms $25 each
Front upper arms $25 each
Reinhard jap made 3" ENR34 SS exhaust with cannon good condition sounds great-$400
R33 GTR radiator with twin thermo fans-$100
AU falcon twin thermo fan setup-$50
R34GTT doors complete-$100 each
Front bar (cut for intercooler) $150
R34GTT/R33 GTR Ohlins Coilovers-$900
Blitz SUS stainless POD filter ok condition-$50 with AFM adapter
R34 tripple guages with autometer smoked volts oil pressure water temp $150
Clear side inticators-$25
BM44 brake master cyclinder with brake booster-$200
18x8.5 18x9.5 Starcorp impuls with tyres-$800
17x9 +22 x4 Sparco light weight wheels-$800
PM for any more info etc everything located in Newcastle
0422646961
Chasing the stereo surround that goes around the din and below the AC controls
AND
The lower dash section between the gear surround and the top of the dash where the gauge cluster is
Must be good condition and need both sent to Adelaide 5067 please
AND
Both items $100 shipped
Hey I'm after the plastic bit under the ash tray and the rear? Thanks
Price listed centre console plastic $100
Hi mate,
What condition are the coilovers in? And just confirming they fit 1999 GTT? Don't happen to know the spring rates off the top of your head do you?
Cheers,
Shazza
Edited by XS80ST
hey shazza... thry were great when thry were in my car handled nicely all dampeners worked fine... not sure on spring rates i belive the part no was nis 10m ? i think i can confirm later if u want ? and yes came from a 98 gtt so thry will fit
Hey, I was just wondering if you are selling the interior door pannels? Also is the steering wheel still in good condition or has the leather started to go on it?
aircon condenser?
yes $100
door cards price is listed $50 each wheel is in pretty good nick
Can you get a picture of the steering wheel without that cover please?
Cheers
posting a pic now
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
