  • 5 months later...
when the pod is on it it makes the sucking noise till It hits boost then it's good.
Til the boost comes on it just has a lack of pull like a vacuum leak.
The pod is bigger then the afm.
Will a 3" pod stuff the afm sensor around?
Thanks Alex
The AFM'c calibration expects to see the air flowing in from the airbox. If you mess about with the air flow patterns, you could quite easily change the reading that the AFM is giving you for any given amount of air. Hence you could end up running richer or leaner than you should, and also the timing would be off as well. Put the airbox back and report if it gets better. If it does, then do not put the pod back on unless you are getting the ECU tuned at the same time.
Also, if there are any nasty step changes in size from the AFM inlet to the pod, then the flow could be made ugly. Inspect and decide if the air flow (in the direction of flow of course) looks like it might be made untidy by any big steps.
Thank you, yeah as soon as the air box goes on its perfect again.
My problem was that the intercooler piping bloked my snorkel off that sits under the bonnet so my airbox is just sucking warm motor air.
I just want an airpod that won't make my car run like crap.
They have cai setups on eBay for $149 but I don't want it to do the same.
A pod filter will also be sucking in hot air from the engine bay.
The stock air box is a well designed Cold Air Intake, and when combined with a high flow panel air filter like a K&N or a BNC is completely fine for cars with over 300rwkw (yours will currently be about 130rwkw)...
If your intercooler piping is blocking the snorkle, find another way to route cold air into the stock airbox, perhaps slightly modifying the snorkle by cutting it and resealing it with tape or whatever...
Sounds to me like you've got a FMIC which returns to the engine bay on the drivers side.... Bad boy.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
