Well so far it owes me $20 worth of fuel hose and the apple juice itself . Having that Eflex servo closer than the other two seals the deal and fingers crossed more around soon .
My car should go better again with a propper tune and if it has better part throttle torque than now it can probably use a bit more intercooler and turbo .
It still breaks traction in second (pre Eflex and a cold dry morning) but the Mitchy Super Sports are on the water and should help improve traction . If it doesn't will need a better diff center .
First cold start soon , cheers A .
  • Replies 87
Ok first cold start took about threeish seconds to fire and ran well . I got a wiff of the good stuff so must be tossing plenty in .
I have not touched any cold start stuff yet but I'm thinking of increasing the cranking enrichment rather than the actual coolant temp based enrichment .
It was a slightly jerky around 1500 revs but I've altered a few other things which I think will solve that .
This Eflex makes my engine run smoother and idle better than Ultimate 98 did . I've mainly been trying to make it drive nicely at low revs and ATM it pulls smoothly away at 12-1300 revs in 3rd so no complaints there . I'm not sure what timing numers I can input at low revs and light loads so just playing around with this ATM . This car was always a bit touchy at very low revs in 1st and its lightened flywheel doesn't help with slow speeds and taking off . Its much better now and getting better as I muck around with the PFCs settings .
Overall I think going to E85 , well Eflex anyway , is a good step to take because it allows you to get the best out of your current engine with tuning and is far simpler than changing engines . In my case I already had the Z32/PFC/GTR pump/740s in place and getting it to run acceptably with a few corrections has not been real difficult . Andrew pointed out to me that the only easy legal way to get a 30 short block in was to tune for emissions compliance and take that to a willing engineer to certify . I'm going to see how this RB25 goes and I have a feeling I'll outgrow the GTRS and GTt SMIC in the not too distant future . Really the intercooler needs to be upgraded first and then a tune should show how far a GTRS can go on an RB25DET . I have seen some impressive dyno numbers for a GT28 based turbo in the dyno results section - upwards of 270 RWKW though a lot of other things were improved to get it there . Things like headwork Poncams FMICs e85 injectors - and a good exhaust .
A .
yeah the low down torque of e85 is brilliant..my skyline drives like my turbo diesel Ute down low now , which means I don't have to drop it back a gear to get it moving all the time even with a lightweight flywheel
You won't look back disco.. :D
I gave it a bit more cranking fueling for this mornings cold start but I don't think that made much difference . I really have to get the Tech Edge in to see whats going on . Um also need to keep an eye on the fuel filter , don't suppose someone can tell me the Ryco one for an R33 so I can go grab one or two .
After searching I think the std replacement is a Z201 but the larger diameter Z202 from the R31 and 300ZX Turbo may have more filter area .
Cheers A .
Edited by discopotato03
After searching I think the std replacement is a Z201 but the larger diameter Z202 from the R31 may have a bit more filter area .
Cheers A .
From personal experience, that "OMG, your filter is gonna clog up with 10 kg worth of shit by the time you drive around the block" is rubbish. I ran mine for 6 months and had a look at it and both filters were clean as.
Actually I mentioned this crud into alky converted cars business to Gary (Sydneykid) and he said provided cars are driven from full tank to almost empty often it shouldn't be a problem . He said many people never run their cars below half a tank but the day they have to go to virtually empty they get a system full of crud .
Anyway they opened the filter on their Lancer and it was clean too . I was planning to run this first tank of Eflex through and then replace the filter which has been there for 19k km .
A .
The sock filters on my Walbro's are black, there is definitely something very fine slowly building up on them over time. I came to the conclusion last year that there must be a slight sediment in the fuel as my fuel system checks out. I have been on e85 for over 3 years now (daily) so any original crud would have been cleaned out surely. From my searches it seems like a common problem in the US, perhaps carbon from some filtering process?
No big deal to change filters every few years though...
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
