That was what I was trying to explain to you in your other thread...:) Definately need a drop on 20s.
seano,
wasnt your car slightly lower than your mates?
just because you havent upgraded springs doesnt mean a previous owner didnt. you could have Z springs and not know it...
clean the springs and check for any spots of paint colour, theyll ID the springs,
Edited by Deep Dish V35
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486137
seano,
Very good point, i will check this when i change my comp rod bushings. I doubt it though you would assume the previous owner would mention that as a selling point.
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486160
Could be right, my car does look a lot lower than the pictures above though. Might just be because my rims and tyres are only stock 18s but yeah. When i get time to do my comp rod bushings i'll take some pics of the springs is there any way you can properly tell apart from paint marks?
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486235
I wouldn't rely on photo comparisons alone to determine if you are lowered or not. Your springs and shocks could well be tired and sagged a lot more than your mates both being factory suspension. As I mentioned earlier as well, overall wheel diameter could also have an effect, so maybe let us know what tire profiles you are running on your 18s as well. A difference or 10-15mm could give u a slightly lowered look
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486269
I'll buy your mags. how much? :)
$800..fair call? .Im in perth. They look nearly identical to BMW rims.
I'm at work for two weeks now so if you're keen txt me 0427197256 They are still at the tyre shop.
Marshan: No I wasn't running 17's, I was running 19's LOL
And yes, will get it lowered eventually, one thing at a time!!
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486510
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
