That was what I was trying to explain to you in your other thread...:) Definately need a drop on 20s.
seano,
wasnt your car slightly lower than your mates?
just because you havent upgraded springs doesnt mean a previous owner didnt. you could have Z springs and not know it...
clean the springs and check for any spots of paint colour, theyll ID the springs,
Edited by Deep Dish V35
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486137
seano,
Very good point, i will check this when i change my comp rod bushings. I doubt it though you would assume the previous owner would mention that as a selling point.
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486160
Could be right, my car does look a lot lower than the pictures above though. Might just be because my rims and tyres are only stock 18s but yeah. When i get time to do my comp rod bushings i'll take some pics of the springs is there any way you can properly tell apart from paint marks?
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486235
I wouldn't rely on photo comparisons alone to determine if you are lowered or not. Your springs and shocks could well be tired and sagged a lot more than your mates both being factory suspension. As I mentioned earlier as well, overall wheel diameter could also have an effect, so maybe let us know what tire profiles you are running on your 18s as well. A difference or 10-15mm could give u a slightly lowered look
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486269
I'll buy your mags. how much? :)
$800..fair call? .Im in perth. They look nearly identical to BMW rims.
I'm at work for two weeks now so if you're keen txt me 0427197256 They are still at the tyre shop.
Marshan: No I wasn't running 17's, I was running 19's LOL
And yes, will get it lowered eventually, one thing at a time!!
https://www.sau.com.au/forums/topic/406930-my-new-20-rims/#findComment-6486510
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
