I will be advertising this in the main section as well, but i had it on good word to poke my head in here and advertise as well (for you 260RS nuts)
For sale i have a custom high mount twin turbo setup off an R32 GTR. Basically everything you need here to change from low mount to high mount (bar a couple of dash fittings for the block)
In this kit you will get:
2x Garrett 2860 -7 turbos (NOTE: please read at the bottom regarding turbo condition)
2x steampipe manifolds made by Garage 7 - T2 flange
2x custom 2.5" dump pipes with 5 bolt flanges (where they combine into one, they become a 3.5" pipe with a 3 bolt flange)
2x custom intake pipes with Drift brand air filters (these pipes can be trimmed shorter to fit AFMs)
All custom braided oil feed / drain and coolant feed / return lines (see note at bottom also regarding extra fittings)
Custom Y pipe to meet up with factory rubber intercooler pipe joiner (obviously to suit R32 engine bay)
Vaccum hose for both actuators (with heat shield sleeving)
Oil feeds are -6
Coolant feed / return are -8
Oil drains are -10 (teflon braid used for these)
This setup made 355rwkw / 500nm on 20psi, and had a lot better midrange compared to stock low mount manifolds. Has a unique sound too
From the stock setup, you will need to add / modify the BOV recirculation (i have removed my factory BOV pipework, it just needs a pipe teed into the y pipe before the joiner) or remove it all
You will also need to relocate the power steering resevoir to allow clearance for the rear intake pipe (i was easily able to move it to the bracket that held the carbon canister on the radiator support panel between the radiator and the back of the LH headlight). Small piece of hard line "bundy tube" and the job is done
Regarding fittings: You will require a few Speedflow/Powerflow/Aeroflow style "dash" fittings to complete the job, i still require the ones that arent supplied. One picture
Regarding turbo condition: The rear turbo (the one pictured with the longer hot pipe snout) has had a bearing failure. Has been quickly checked and will require a rebuild. I would get the other checked at the same time just for piece of mind
Basically whats pictured is what you get. Its a unique look, and needs a good home. Ive decided to go down a single turbo path on my 26, so no longer can use any of this gear. All of the stuff was made up last year, and the car has been driven next to nothing in that time
Im looking for $1750 for the whole kit, but i am negotiable too. Contact me via PM for any more information
Will freight interstate, let me know of your postcode and i'll try and get the best price possible
Pics
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
