Just wondering if anyone else is having a problem with their GTR having tomei poncams (and no aftermarket cam gears!) installed and starting in the cold. When I start my car cold the engine almost cuts out at idle. Is this happening to anyone else? Would cam gears help this??
It might depend on which poncams were installed Michael but...
Can you and your mechanic do a comp test?
> if required, check if your belt has slipped a tooth on the cam gear?
> if so, what belt brand is it?
n11smo has had his VS2 at a painter 2 weeks ago
> it has Tomei poncams and cam gears
> painter couldn't start (cold Penrith temp)
> car got towed
> inspection revealed that the belt had slipped big time
> belt does not look like OEM or Nismo
> all the valves down one side are bent
> JapLink is "looking after" n11smo as an act of compassion
Offender was the poncam on inlet? Or the belt (gates)? Or the painter starting the car who may have revved it whilst moving it? Don't know.
Tez I have the type B poncams and compression on all 6 cylinders is 170 psi.....it may very well be the timing belt. It'sa good thing then that I just ordered a nismo one and Tomei cam gears also :D I'll keep you posted and let you know if they fix the problem once installed.
> car got towed
Lesson learnt.
Upgrade belt when upgrading cam gears and camshafts.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
