No dont do it , its defect for one and the bouncing is a dead give away on hacked factory springs !!
dont go too low , stance looks cool but handles poor , oz roads suck and the bumps will annoy the F out of you or tear off the guard lips and your tyres
And the handling suffers from hitting bump stops and shocks bottom out , most r31 are tired now so do it right with shocks and springs ( check r31 forum ) lots of used but useable shocks and king springs floating around for cheap
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6486185
yeah i was thinking the kings springs an maybe drop it 30mm but as u know the back of the r31 is higher then the front. would it be a ratio of 30mm for fron an like 50mm for the back?
as for the chop i was just asking i def know its not good to do to your car as my mate done it an he said it rolled an carryed on heaps
if i change the springs to kings springs would i need compleatly new shocks? if so do i just get standard shocks or ones that are lowered or some crap ( im new to this thing lol)
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6486209
Cant remember how many mm my past 3 r31 were lowered think about 25mm
if your current shocks are newish and not leaking
You can lower a bit but the bumpstops will hit , you can find lower ones or trim off a little of the current ones , but remember once your on the stops your driving no suspension and in a high speed corner your heading for the trees , it slams down and unloads the wheels in a bad way
The r31 suffers heavy engine sags front springs
And worn balls joints etc is common so if all that is in good nick new springs will bring it more level
Chuck in a sub and amp and your level haha
kings ride way better not like a wandering boat
you might have load /towing shocks or helper springs if the car has towed before so check first
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6486255
hahahah!!!! sub an amp to lvl it out hey.. nice!! hahaha. i kinda wanna do it right lol. and im not racing it or anything ( although tempting) so slammin into a tree at high speeds wont be an issue dude lol. and it seems it never had a tow bar or anything like that so i should be sweet. so a set of 30mm king springs u think would be the go hewy?
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6486276
To do it right means new shocks as well ? But the cost will skyrocket fast. New bushings most likely too
Depending on rims 30 mm might be enough or too much ? Offset and diameter
You dont need to be racing to have your bumpstops fling you off the road in the right circumstances it can do it any just about any speed , you go from shocks to solid frame handling but its very unpredictable and unsafe
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6486499
i have a 1989 r31 and im just wondering if cutting the springs in it is ok? ive read up some ppl say its fine and others dont. any one care to enlight me please?
just get some lowered springs.
its not expensive.
if you have any questions, call your local suspension place and ask them.
https://www.sau.com.au/forums/topic/406969-chop-drop-r31/#findComment-6497651
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
