Skyline r32 20det missing and stalling, will be driving and acceleration cuts out for a few seconds then put foot back down and comes back, or like today for the first time won't come back and stalls, or stalls randomly at lights and has trouble starting again sometimes, has run great for 8 months, just started this a few days ago, seems like it's doing it more and don't like driving knowing I could break down at traffic lights if it decides to stall and not want to restart ...
AFM connection, coils, fuel pump or something? anyone had this prob? needa sort it asap
Does it only happen when car is warmed up?
Sounds alot like when my old Bluebirds CAS was on it's last legs.
Cutting out at approx the same place daily on the way to work, ignition cutting out and kicking back in, stalling and not wanting to start for a couple of minutes etc.
New CAS, no problems.
Could also be AFM related but I'm leaning towards CAS.
Search for "Crank Angle Sensor" & see what comes up.
Edited by Not a Pulsar
I think it is only when it's warm, I'll see in the morning as I need to get to uni, not looking forward to driving it at all was hoping it would at least be OK through till friday but it seems alot worse... may have to try hunt down a cas tomorrow, or find out if some one can confirm the problem.. thanks so much for the help at least now I have a likely cause for this... its very annoying!
Freaks you out when your'e hummin' along and suddenly everything stops.
Popping the bonnet at the lights isn't much fun either.
Goodluck, hope you get it sorted soon.
Oh and Welcome to SAU !
Yea never had any problems up till now, have searched up symptons and there's been too many causes to figure it out.. like air flow meter connection, coils, cas good to get some peoples opinions here as well to match whats happening, wish my car could talk and just tell me wassup
ECUtalk cable, its the most practical imo, comes with a USB connection and software !.
Dont go the chinese route and get a RS232 those things are so oldschool you need a laptop with a RS232 port,
if you dont then you need to get a USB-RS232 converter and thats just annoying you will end up
spending $$ to get it to work. ECUtalk best bet its like $80 and in with the times.
Its a poor mans Multi Functional Display.
Edited by starwarz
  • 1 month later...
Thought Id bring this thread back.
Tonight something weird happened. I was driving (just entered sydney from the central coast), slowed down for a round about, and got through it, then on the other side I applied about 5% throttle just to coast along, and it hung on to 2,000 rpm for at least 2/3 seconds I was then about to get off the throttle, and then it started to gain revs again.
Then I pull into the garage, park, I then jump out to have a sticky beak at any noises, and I can hear the car slightly dropping and picking up revs, power fc said about 200/300 rpm. And then it stalled, so I crank her up, she starts first go, and I let her idle, same thing again, stall after about 10 sec.
Hmmmmm... Im thinking my AFM is farked, or TPS. Am I on the right track? Im going to check tomorrow to see if its still doing it, if it is still misbehaving then Ill unplug the AFM's and see if it persists.
Or am I just chasing my tail and I should be looking at the CAS?
BTW, if my AFM's are f**ked then, Jez mah man, get that LINK ready
Its all apart atm. Cas is looking good still. Gears still have good teeth.
Afm, one has some oil on the element. Will be cleaning them and putting cstch can in to prevent this in the future.
If this doesnt fix it, then I am done with afms haha
Mine is still doing it, have taken it into get fixed and they did an oxygen sensor somewhere under manifold and the spark plugs which they thought fixed it but turns out once I got it back wasnt fixed so she's going back in.
@Hadouken Mine has started doing something similar to yours over the last 2 weeks which it wasn't initially doing once the missing started, when it's idling she can't keep the rev's stable, stays stable a little bit, rises, falls, rises, falls, and usually will end up stalling, sometimes quickly sometimes takes a bit. As you can imagine this is annoying as hell at traffic lights...
Oh well, gotta get through this week with her in this condition in the city while I'm at uni and take her back home to get back into the workshop and use a family vehicle while it gets fixed...
Edited by LoveofCuteness
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
