Few Upgrades to go onto my car soon ( hopefully within 2 weeks )
What power you recon when all parts are on at ~ 14-15 pound boost.?
Purchased :
All items for a 100k Service
600cc DeatschWerks injectors
Exedy Sports Organic Clutch
To be Purchased:
Hypergear ATR43G2.5 Turbo Kit
Nistune ECU/Tune
BC Coilovers
On Car:
Gizzmo Ms-ibc Boost Controller
3 inch Just Jap Straight through Exhaust
Splitfire Coilpacks
350z Rims
Just Jap Front Mount Intercooler
https://www.sau.com.au/forums/topic/406999-r34-upgrade-soon-predictions/
  • Replies 41
I cant afford the stuff i have :P
But i was more referring to the things like Excedy Organic clutch = :no:
Fuel pump was mentioned, not sure what the stock ones handle but i dare say they wont handle 250kw
Probably invest in a Z32 of your going to the expense of a full tune with a NIStune, you'll need to do it later anyway.....
Depends what dyno the reading is done on, get a on high reading hub and you got yourself a extra 90hp on paper. You will need a Walbro kit & Z32 + plug, both easy to fit. 300-350hp. I've got a few here. Clutch should be fine if it is fresh, just remember it's organic compound so it won't respond to best to launches and cooking off it.
Don't be concerned by the number, I've had 80hp~ reading difference in the past with local HUB/Rollar dyno's in WA.
Edited by monga
Whats wrong with the Clutch? I didnt want a harsh clutch and i heard people easily run that clutch for drifting...and im aint doing drifting ..lol
So a Z32 and a new fuel pump?, Whats a straight swap fuel pump available?
The cushioned button is near stock feel and rated higher in terms of power....... Although it wasnt rated to my power........ Ill have pics up when i pull the gearbox out tomorrow :P
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
