Few Upgrades to go onto my car soon ( hopefully within 2 weeks )
What power you recon when all parts are on at ~ 14-15 pound boost.?
Purchased :
All items for a 100k Service
600cc DeatschWerks injectors
Exedy Sports Organic Clutch
To be Purchased:
Hypergear ATR43G2.5 Turbo Kit
Nistune ECU/Tune
BC Coilovers
On Car:
Gizzmo Ms-ibc Boost Controller
3 inch Just Jap Straight through Exhaust
Splitfire Coilpacks
350z Rims
Just Jap Front Mount Intercooler
https://www.sau.com.au/forums/topic/406999-r34-upgrade-soon-predictions/
  • Replies 41
I cant afford the stuff i have :P
But i was more referring to the things like Excedy Organic clutch = :no:
Fuel pump was mentioned, not sure what the stock ones handle but i dare say they wont handle 250kw
Probably invest in a Z32 of your going to the expense of a full tune with a NIStune, you'll need to do it later anyway.....
Depends what dyno the reading is done on, get a on high reading hub and you got yourself a extra 90hp on paper. You will need a Walbro kit & Z32 + plug, both easy to fit. 300-350hp. I've got a few here. Clutch should be fine if it is fresh, just remember it's organic compound so it won't respond to best to launches and cooking off it.
Don't be concerned by the number, I've had 80hp~ reading difference in the past with local HUB/Rollar dyno's in WA.
Edited by monga
Whats wrong with the Clutch? I didnt want a harsh clutch and i heard people easily run that clutch for drifting...and im aint doing drifting ..lol
So a Z32 and a new fuel pump?, Whats a straight swap fuel pump available?
The cushioned button is near stock feel and rated higher in terms of power....... Although it wasnt rated to my power........ Ill have pics up when i pull the gearbox out tomorrow :P
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
