all you should do is use the q45 tb and put the rb25 tps on it
It's not that simple. Here a pic so you can see the difference. http://rb25det.org/rb/tps.jpg
left SII, right Q45 (unknown year, pre 1995)
the USDM 1996 Q45 TPS looks like it wil plug into SII harness but I don't know if it will bolt to the greddy IM.
hmm they look kinda the same design but the turning mechanism seem to have different joins or something.
have u got a 1996 q45 tps?
my guess would to be either go this way or u will have to have the tps custom fitted
Nope don't have a 96 tps, however I do have a 96 Q45 FSM. The TPS it shows is similar to the SII TPS, they may have the same P/N.
But getting back to the issue, why does my TPS read ~5V at idle with the SII tps or the Q45 TPS? When at WOT the voltage drops to ~.5V.
Seems it's reversed.
Some guesses......(based on R32)
*you are measuring the voltage between the wrong two terminals. The supply voltage to ground measurement should be 5V. The signal to ground measurement should vary ~0.5V-4V.
*If not the above then are you sure the TPS's are wired in the same way. Because it is a potentiometer if you swap the + & - wiring it will read in reverse.
*Are you sure the TB's actually open with the same rotation eg RB30 and RB20 TB's open in different ways - one opens clockwise and the other opens anticlockwise. The TPS's are therefore designed to rotate in opposite ways and so mixing and matching can mean the output can get reversed.
As a check, get a multimeter and measure the TPS resistance (signal to gound) at idle position and at WOT position (both with the plug disconnected). What readings do you get for both TPS's?
Have you got the connectors on the right way round?
There are 2 TPSs - a Trotlle Position SWITCH, which normally tells the ECU that the throttle is closed or WOT, and a Throttle Position SENSOR, which tells the ECU where how far the throttle is open.
I'm the other guy having the same problem. Both Q45 and RB25 TPSs show ~5V at idle and ~.5 at WOT. I'm pretty sure I have it connected to the right sensor, not the switch. I measured the resistances of both. They both showed ~0.8 kOhms at idle and ~4 kOhms at WOT. When I measure the harness side of the plug (unplugged), I get 5V on one wire, ~4V on the middle wire, and 0V on the last. Is that right, can someone be so kind as to measure theirs for comparison?
Also, can anyone tell me how to check the codes on my ecu? I have an SII RB25, but it has no LED or adjustment screw on the ecu case?
On the R32's there is a diagnostic connector. This is a small brown plug located at the fuse box.
To enter the diagnostic mode you need to short two of the terminals for two seconds. This then puts the computer into check mode and it flashes the results on the ECU led and the engine check light (these are on the same circuit).
I don't know if R33 is different.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
