Just wondering if anyone has used the Earls Dry Brake Couplers for the connection between caliper and hard line? Opinions?
Just ordering my lines now and thinking using these might save rounding nuts/ time and money.
http://www.holley.com/EarlsCatalog/Catalog.asp?pageNumber=62
Luke
No dry brake connection is dry enough to use on brakes. They will all let some air into the lines. Probably also going to raise severe laughter from those who decide what is legal and what is not. Fancy disconnecting someone's brakes by just reaching in and giving a twisty-pull?
Break, not Brake. lol.
Yep, if your talking about the coupler.
Brake = the things that make your car slow down
Break = smash / destroy
So we're talking about break couplers on brake lines....
Says in the description you can use for brakes, oil etc just have to choose the right part number.
It's for the time attack car so basically doesn't have to be road legal.
They work and they work very very well if your using the high end versions not the cheaper fragola ones.
There is no need to bleed brakes they have an air pocket chamber built into them that you can purge if need be but I've never had to do it.
We use them on brake lines, clutch lines, fuel lines on the super cars and extend the use to attessa lines etc on GTR's
Earls aus don't keep any of them in stock though as they are an extremely slow moving component.
If you place a decent order they may air freight them over.
Just what i wanted to hear Brad. Thanks for that.
Have you got a contact in the US you deal with as while the Dollar is pretty strong against the US i might get them along with all my Fuel system fittings.
Thanks
Summit normally stock the common size ones -6 &-8 they can get the larger ones easily enough.
However by the time you pay summits retail (or trade =retail -10%) then freight and taxes,for myself it works out cheaper to buy from earls aus and wait the 6days. So I rarely ever buy direct from summit.
Retail here is far more expensive though having the warranty and support is worth it
Unfortunately due to martin's (earls aus owner) agreement and franchise structure we can't buy direct from earls, Weldon or tilton despite the dollar.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
