What happened was I blew the front ceramic wheel so I got another turbo replaced it then I rebuilt the first engine put it all back together and only making half boost so I assumed one turbo was working and the other was stuffed only found one wheel in exhaust the cat looked stuffed do I sold the engine pulled the turbos dropped new engine checked the wheels on both turbos they both spun free didn't look like blades where missing put it all back together and now no boost at all if the cat was blocked it would be quiet wouldn't it the only thing I've done is pulled intercooler to inspect and put it all back together a totally blocked cat wouldn't the exhaust glow red
Edited by Hot33r8723
  • Replies 56
it doesn't work like that - if one turbo is seized or has lost its turbine, then its compressor effectively makes a hole to atmosphere that the boost from the good turbo will flow out of.
Half boost is a boost control issue.
Just pulled of the pods and intAke pipe on the front turbo and started the car and it's not spinning do u think I lost a wheel if a engines compression was really low on all cylinders would it make boost still
Won't build any boost there is no vacum to wastegates at all there is vacum on my boost gauge
I dont understand how that can be - dont they both connect to the plenum? No vac to wastegates suggests a leak, and if you have a leak you wont make boost.
No. Wastegates get their signal from compressor outlet, not plenum. Plenum bad, compressor outlet good.
Given that they're connected - how much difference does it make? (assuming the intercooler flows well)
Any ideas on how OP gets nothing at actuators but vac at boost gauge? I would have assumed they would be pretty much the same at idle.
Guess what I reckon it is a blocked cat
If the cat is blocked, I highly doubt the car would even run. Try starting your car with a tennis ball in the back with duct tape.
ive seen a car drive perfectly ok with a blocked cat, but there was zero boost..
why would you need vacumn at the turbo actuator, it only needs to open under pressure, so what we have here are 2 turbo's which are supposedly ok... and highly likely a blocked shit cat. and zero boost.
If both turbo's flow there air/pressure into the intake, then you could test each turbo individually to check if they are making proper boost..that would save stripping it all down again..?? and replace cat obviously..
Edited by SliverS2
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
