so i thought id venture down the road of making a custom gauge holder and going the extra mile for once , rather then buying a twin pod pillar holder and have to worry about another reason to get defected. I took a lark with this ruining my air con vents and possibly having to buy a new fascia if things didn't go too well lol.
but to my luck and skill i managed to conjure up this gauge holder , which i now can fit 3 x 60mm gauges comfortably .
procedure : basically i removed the vent and cut out existing plastic in the center . I then grabbed 3 lids off of some spray can bottles , which were perfect to fit my 60mm gauges . i positioned the lids as i desired , and glued them in with some poxy over night to keep position . the gauges fit perfectly in the vent without any cutting .
once everything is dry i covered the back of the fascia / cups with some packaging tape ( which prepares for the spray of foam) basically i just filled the vent in with foam which drys and forms my substrate.
from then i used a dremil to shape the foam into my desired look . then the shit part comes into play , butter the foam with a good layer of filler/bog , shape the curves as best i could so i have less sanding . once dry basically spend my time with a dremil flattening the filler and shaping it so it is easy to sand . now an hour of good sanding .
finally on to spray , i packed it up with a few layers of thick 2k primer , and repeated a few light 400 grit sands in between coats . i chose to spray it gloss black with 2k .
I'm pretty impressed with my results , and i have no dicky gauge holder sitting on the dash or any pod pillars obstructing vision .
Edited by sky017
  • Like 1
https://www.sau.com.au/forums/topic/407033-custom-diy-60mm-gauge-holder/
That's mad, great work.
Now just make it in carbon n send it to me
Lol no prob it would take a day to make out of carbon , did my gtt already ditched the cig and ashtray for 3 gauges out of carbon flush fit like a iphone screen and my in dash pop up tv was 5.6" now its a carbon fiber 8" wide screen and lots of other carbon goodness , photos will be posted after magazine shoot
  • 1 month later...
  • 1 month later...
Have you had the shoot, would love to see photos!!!!
  • 9 months later...
Hi all.
I loved this idea soo much, I decided to copy it. heres a few picss of my version, its a little different. I used pvc fittings for the gauge holders, and the all angled towards the driver, but all in a line ;) ..... if ya know what I mean. I used expander foam and body filler, just the same as you did, worked great. if the bog is to thin though, the foam makes it a little soft underneath, so id say, use the foam only to hold things in place, then mostly bog for the shaping. any way, have a look :yes: Thanks heaps for the idea!
That looks sweet! Only wish you could replicate the original orange peel finish, not a fan of gloss. Maybe some VHT wrinkle finish satin black would work.
yer, would be nice to get it looking original. ive used satin. Ill probly trt and vinyl wrap it soon, in something similar to original. the orginal paint is crap as, just rubs off ay?
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
