so i thought id venture down the road of making a custom gauge holder and going the extra mile for once , rather then buying a twin pod pillar holder and have to worry about another reason to get defected. I took a lark with this ruining my air con vents and possibly having to buy a new fascia if things didn't go too well lol.
but to my luck and skill i managed to conjure up this gauge holder , which i now can fit 3 x 60mm gauges comfortably .
procedure : basically i removed the vent and cut out existing plastic in the center . I then grabbed 3 lids off of some spray can bottles , which were perfect to fit my 60mm gauges . i positioned the lids as i desired , and glued them in with some poxy over night to keep position . the gauges fit perfectly in the vent without any cutting .
once everything is dry i covered the back of the fascia / cups with some packaging tape ( which prepares for the spray of foam) basically i just filled the vent in with foam which drys and forms my substrate.
from then i used a dremil to shape the foam into my desired look . then the shit part comes into play , butter the foam with a good layer of filler/bog , shape the curves as best i could so i have less sanding . once dry basically spend my time with a dremil flattening the filler and shaping it so it is easy to sand . now an hour of good sanding .
finally on to spray , i packed it up with a few layers of thick 2k primer , and repeated a few light 400 grit sands in between coats . i chose to spray it gloss black with 2k .
I'm pretty impressed with my results , and i have no dicky gauge holder sitting on the dash or any pod pillars obstructing vision .
Edited by sky017
  • Like 1
https://www.sau.com.au/forums/topic/407033-custom-diy-60mm-gauge-holder/
That's mad, great work.
Now just make it in carbon n send it to me
Lol no prob it would take a day to make out of carbon , did my gtt already ditched the cig and ashtray for 3 gauges out of carbon flush fit like a iphone screen and my in dash pop up tv was 5.6" now its a carbon fiber 8" wide screen and lots of other carbon goodness , photos will be posted after magazine shoot
  • 1 month later...
  • 1 month later...
Have you had the shoot, would love to see photos!!!!
  • 9 months later...
Hi all.
I loved this idea soo much, I decided to copy it. heres a few picss of my version, its a little different. I used pvc fittings for the gauge holders, and the all angled towards the driver, but all in a line ;) ..... if ya know what I mean. I used expander foam and body filler, just the same as you did, worked great. if the bog is to thin though, the foam makes it a little soft underneath, so id say, use the foam only to hold things in place, then mostly bog for the shaping. any way, have a look :yes: Thanks heaps for the idea!
That looks sweet! Only wish you could replicate the original orange peel finish, not a fan of gloss. Maybe some VHT wrinkle finish satin black would work.
yer, would be nice to get it looking original. ive used satin. Ill probly trt and vinyl wrap it soon, in something similar to original. the orginal paint is crap as, just rubs off ay?
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
