Yes
Where are you located ?
Stear clear of jaycar cheap plastic ones they work but design isnt suited to this climate longterm and reception could be issue on it in fringe areas
Have it pro installed please !!
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6488495
  • 2 months later...
got suggestions, terry? gathering info for when i get my own car
The viper / cliford/ pyrhon system but it costs money yearly- not optimal but works
Mongoose
Think autopage has one
Many mainstream brands are available
eBay- metal case with external gsm and sat antenna's , finned case is better due to heat here
But work perfectly fine if they use 3 band spectrums , use a full size prepaid sim
One of the thing to watch is heat , the plastic cases warp and melt , most are rated about 50-60c and your car exceeds that easy in summer sun
Needs external antennas for better cover in fringe areas or black spot cbd areas
the ability to use your smart phone/ google maps pc etc to track, geofence , shut down the car remotely of course you wouldn't do that unless the car is stopped or moving slow, instant loss of power steering could be fatal and we all no crims have more rights then victims?
If the car is driven By others geofence and speed alerts via sms or email with coordinates
a backup battery that lasts at least 12 hrs
A alloy or steel case that is screwed together
Not snapped together !!
Installed by someone who knows how to integrate and hide it like a factory install
If you can find it in 15 min or less its not installed properly behind the radio doesn't cut it
At the point a thief rips the car apart its the last line of hope of finding it in most cases so the longer it takes to find the better , skylines have some great secure hiding places ;-) as long as they cant trace the loom back
If you use prepaid sims make sure you have credit , and its not expired lol you know so many people still run around with no credit on cells phones so tracker is going to be worse lol
Test the tracker monthly !!!
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6596090
Terry - hahaha thanks. surely your beauty has security, if it's good enough for you then it's good enough for me!
Troy - holy crap you are a repository of information. thank you heaps. that sounds like it will cost a LOT ... but will be worth it i guess!
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6596194
Cost wise
Viper system i think is about 300 ish plus install and yearly fees
Others about 150-300 plus install
Plus sim card charges for a year , only need sms unless you buy a tracker with 3g camera function added on to stream the drivers face to your device or cloud lol
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6596439
Mongoose
Thanks Troy,
The guy is a biased against Viper, but I'll tell him to research Mongoose/Autopage!
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6596493
Thanks Troy,
Yeah i agree I like DEI products( viper etc ) but they shot themselve in the foot by charging yearly fees to monitor the car
in the usa market its more or less "lojack" and " onstar" and DEI aftermarket , all pay services at one point
In oz we like to DIY monitor of the car unless its a company fleet car or truck
Edited by Carbon 34
https://www.sau.com.au/forums/topic/407034-alarm-tracker/#findComment-6596716
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
