Hi guys, my diff is on the way out, and i was wondering:
1 If anyone has ever fitted a non Skyline diff in a Skyline, and what was it, how was it done.
2 Or, What diff centres fit in what housings, which housings fit in which models (can i put a 33 diff on my 32)?
I want to fix my diff on a budget, so any useful info is appreciated.
https://www.sau.com.au/forums/topic/407035-diff-replacement-options/
R32 and R33 are the same diff, but there are differences. The R32 rear mounting points are different, so you'd need to swap back plates over. The R33 diffs use bushes in teh front mountss and the R32 doesn't. So you need to obtain bushes to fit an R33 housing to an R32.
The internals are essentially the same (both crappy VLSDs, 4.11 and 4.3 ratios for manuals and autos). Aftermarket diffs sometimes use different length half shafts (like, they'll use one the same length as the Nissan diff, and another a different length to the Nissan diff).. That can be a complication if you're sourcing a centre from somewhere and it doesn't come with everything you need.
Helicals from S15s can be used. I put a 4.11 crownwheel and pinion onto an S15 helical centre and put the whole lot into my R32 housing. Cost a fortune in the end, just about could have gone for Nismo 1.5way instead. Some R34 manuals were helical, and those diffs will drop in in the same way that an R33 one will.
There are not any really useful non-Nissan internals you would put inside a Nissan housing, and there are not really any non-Nissan housings you would bother trying to put into an R32 chassis. Too much f**king around for little gain. The Nissan R200 is a pretty strong diff.
So the easiest is take it to the diff dr,
the cheapest is a second-hand centre from 32, 33, or helical 34s.
Sounds pretty straightforward.
Thanks for complete info, everything i need to know.
:thumbsup:
Has anyone noticed much diffrance with getting power to the wheels with a diff such as a Nimso - Or even one shimmed to specs
Helped with traction?
The way i see it- Its a locked diff that allows both wheels to spin at the same time- Kind of defeating the purpose of the diff in the fact it was designed to allow both wheels to roate at diffrent speeds.
Just thinking from a street/circuit racing point- I can understand for drift single legger would not be as efficent and predicatble.
Edited by sydking
Question is serious?
An open diff does what a diff is supposed to do, which is to allow you to drive around bends without the left and right wheels fighting each other because of the different wheel speeds required to cover the different length paths. An open diff will usually spin up on wheel under heavy acceleration, and is therefore useless in a performance car.
An LSD (I presume you are talking about the Nismo LSDs, and not some solid spool diff that Nismo may or may not do that I don't know about) is intended to reduce the tendency to spin up one wheel. They do not "lock". There is a maximum differential torque that they will handle before they will allow slip to occur between the two wheels, and hopefully that max torque is higher than the expected loading in the application it is installed in. If you hit them hard enough you can still make them slip relative to each other.
And yes, it is all about traction. Better 2 wheels spinning and actually providing some drive than one wheel spinning and providing none at all (in the extreme case), but at anything less than the extreme case, you get to apply acceleration up to the grip limit of the two wheels together, instead of up to the limit of whichever wheel has the lowest grip (and so would spin first).
Always serious mate, Cheers for that.
Just trying to work out what i should do for my gts4- as the rb26 now in im thinking il require something shimmed up to help get the power down,
Just been reading the DIY diff shimmin thread- Some good info and results in there too, I think it could be the go
Edited by sydking
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
