4 hours ago, drifter17a said:
sorry to re open this old thread but my question is related.
I have been calling supplier and have been told nistune is limited to 480bhp by one, is that true?
my car is r34 gtt
Ha!
2 hours ago, Dose Pipe Sutututu said:
Rubbish, who told you that?
^This!!!!
Who told you that?  Or, more to the point, did you misunderstand what they told you?  The ECU does not have a HP limit.  The AFM does, and any AFM you upgrade to will also have a max amount of air (and therefore power) that it can handle.  Fuel injectors ditto.  Turbo ditto, fuel pump ditto, intercooler ditto (although a bit more blurry, not so much of a hard limit), etc etc.
Edited by GTSBoy
  • Replies 44
Askd few times as i suspected he meant the z32 afm but he said the software and z32 hence why i am asking
anyway, how are you finding nistune? Would you have invested in link g4?
it has quite few features but not sure if i would ever use it
does nistune provide an option of protecting engine from blowing up by reducing boost or limit rev if hot?
i think something like link does
Software + Z32 = Z32.
But no-one in their right mind would use a Z32 AFM these days.  That's so f**ken' 2010.  R35 GTR type blade AFMs are 10x better.
Nistune is great.  The engine protections available are limited to what is present in the factory ECU, so, no, none of the more esoteric things you can do with aftermarket ECUs are possible.  But then it's horses for courses isn't it?  If it's a street car, then you don't really need that stuff.  If it's a hack drifter (and let's face it, all drift cars are hacks) then there's no sheep stations at risk and you also don't need it.  If you're racing for serious, then you should probably be using an aftermarket ECU anyway, even if the Nistune would be perfectly capable of running the engine to the same output.
i won't comment on Link ECUs as a choice.  If I was paying for an ECU, I think I'd pay proper money and buy a proper ECU.
Buy a HPX sensor, install it on the side, post IC
Nistune does some "basic" engine protection such as retard timing on knock and setting a rev limiter when your water temp exceeds whatever temperature.
There's a new release for boost duty cycle based on flex percentage.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
