Hey guys.
I bet close to all of us who have leather seats have and will come across the cracking of the vinyl on the side of our seats.
I went to my local trim shop and asked them to replace the damaged vinyl.
They did but it wasn't even close. (why to light)
So i email a company "http://www.leatherrestoration.com.au/" and they said they could make me a kit to restore my leather and paint my vinyl to match.
I posted my old vinyl that was damaged to him so he could match it.
$140 later and i got my kit.
I did 3 layers of color on the leather and 5 on the vinyl to get the color right.
https://www.sau.com.au/forums/topic/407096-leather-restoration/
Lucky i'm not touching the vinyl.
P.s you can't buy the same color new
cool, from the pics i see did you clean it a lot?
and looks like mostly ware and tear and sun damage if so try a leather feeding it re-moisturizes the leather and makes it last longer when leather dries out it tends to decal from my understand from work lol
i would not suggest vinyl paint as people in the car selling industrie use it to hide defects that will show up later on if you want a more permanent fix i sagest getting a re-trim in more durable leather
Never in my life have i heard of this happening, i've been selling new & used cars for close to 2 years.
I "clean" the seats about 4 times a year but i condition them heaps to keep the leather soft, shiney and smooth
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
