Hi all
Ive got both options available at the mo as both are available in full kit form locally
however the turbo kit has no ecu,so what do you suggest for the piggyback?
Or should i go the blower which has the a/m ecu? Decisions!?!
https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/
  • Replies 80
what is your power goal?
Uprev for the ECU will work as long as you keep the AFM, even if upgraded AFM and will be most probably the cheapest/easiest solution.
Are you doing work yourself or handing it over to a workshop? Budget? Location?
i have a mate who has done the supercharger kit on a vq35de and has worked on lots of turbo cars before, as hes a mechanic
im in perth and no-one really does v35s over here. im a boilermaker so exhaust fab is no issue.no set budget as such.
leaning toward turbo kit cos its garret with hks pipes intercooler etc. any feedback much appreciated, might buy it tomorrow.
saw the kit, was mint and the price was too good not to buy it
so i did :yes:
brand new garret with hks gear even chucked in the auto upgrade for free
stoked- install next week 350hp here i come
Nice, got any pics? How are you tuning it?
the kit is an HKS special turbo system kit gt3037 56t
i can get a perfect power smt8 ecu for nothing, is this an anyway decent unit? or should i buy something else?
tuning at a mates workshop, its not what you know........... :rolleyes:
it has instruction manual in japanese but i know someone.... also the kit is made for a vq35de so shouldnt be a big issue
my car has a nismo a/m exhast and i know a guy who wants to swap mine for his coz he took a turbo kit off his putting it back stock to sell.
i know a guy with big injectors for sale if required and i have nismo irridium plugs in it looking into afm now
You will probably need colder plugs anyway. Do you have the number of the ones you put in?
I can get Bosch 1000's that drop straight in and idle perfectly for around $600 new, so don't pay too much for second hand ones, in fact I would be buying new anyway.
Your mate is going to be pissed with you, it isn't an easy kit to fit. Probably easier to pull the engine. Any idea what boost you plan to run? Has the tuner worked on VQ's before?
You might know a lot of people- But I installed that kit, got the tuning software, and made it run. On a car it was never designed for. So I know exactly what you have to change.
All I hope is that the people you know have some decent knowledge about VQ35des and turbos. Otherwise it'll never make it off the dyno. I suggest you research some more.
yeah hes done a vq with a vortek blower kit install in a 350z. My turbo guru has 15yrs exp with snails and charges in cartons of beer :no:
If he doesnt know it its not worth knowing so im in good hands.Im planning on 7psi at this stage cos thats what the previous guy ran on his.
Any thoughts on the perfect power smt8?
cheers
As PN-Mad said ther are many better options,
Haltech Platnium Pro (new one swaps the ecu completely), old one plugs into it <---- One of these prob the best option ~$2600 new, $1400 2nd hand from usa
Utec with MAP sensor <--- piggy back but also acts like a standalone after certain RPM <---- Pre Osiris was the best affordable EMS, $1000new (no longer made), $450/500 2nd hand from usa
Uprev Osiris <--- Cable and software to flash your stock ECU, good for a upto certain HP, but you need upgraded MAF $600 new, 2nd hand varies $400ish - there are more $ types like tuning model or something
The Haltech and Utec both run MAP sensors which you use instead of the MAF sensor.
Haltech is a must for another over 500HP id say
Utec is good if you like the extra like external map selector, boost controller etc and good for up to 500HP, maybe more
Osiris i dont know what HP this is good for...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
