spartacus77 Posted October 16, 2012 Author Share Posted October 16, 2012 pics in my profile garage if u need proof 294.7rwhp until it leans out. need bigger injectors cos im only running 6.5psi look at mod pics thanks to dean at WA automotive specialists in perth, and Jamie for his MEGASQUIRT ecu which did what a haltech couldnt goes fkn hard Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6582264 Share on other sites More sharing options...
spartacus77 Posted October 21, 2012 Author Share Posted October 21, 2012 the ABS light is coming up on the dash and we cant figure out why. anyone got any ideas? doing the dyno power run tomorrow so will post the sheet up after work to keep you number guys happy lol. no matter the figure its a different animal than it was might have to plumb that screamer back in though its f@#!$n noisy! also did anyone have a funny little aerial on the drivers side dash in their v35? i thought it was something to do with the toll roads but it was conected to lots of little modules and boxes one which contained a brand new brown nissan key that didnt fit my car????? does this have something to do with the abs maybe? beats me. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6588417 Share on other sites More sharing options...
PN-Mad Posted October 21, 2012 Share Posted October 21, 2012 Just get a scanner and read the diagnostic code. That will lead you in the right direction. When you can achieve full boost very early, I'm not sure a screamer was the right choice. Mines plumbed. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6588422 Share on other sites More sharing options...
spartacus77 Posted October 21, 2012 Author Share Posted October 21, 2012 the kit came with the screamer but ill weld it up tomorrow got plenty of tube and flanges handy anyway. not showing any codes thats why im confused. any ideas about that little antenna thingy? it was wired into a lot of different things Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6588564 Share on other sites More sharing options...
PN-Mad Posted October 21, 2012 Share Posted October 21, 2012 Think it might be to do with the security and GPS system in the pop up dash. Just leave it alone. Nothing to do with abs. Abs computer is different to motor ecu, so codes won't come up with the manual process I think. Needs compatible scanner. Otherwise don't worry about it. Remember you have stock injectors before you go into heroic power attempts...make sure your tuner is monitoring knock. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6588704 Share on other sites More sharing options...
spartacus77 Posted October 23, 2012 Author Share Posted October 23, 2012 dyno sheet as follows Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6592166 Share on other sites More sharing options...
spartacus77 Posted October 23, 2012 Author Share Posted October 23, 2012 thats just under 7psi. lovin it!!!! Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6592171 Share on other sites More sharing options...
spartacus77 Posted October 27, 2012 Author Share Posted October 27, 2012 let the missus drive last night cos i had a few. not a good idea lol whats the best cleaner to use on leather seats??? shes driven my mates boss270 and thought that was a fast car,until last nite never again methinks Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6598284 Share on other sites More sharing options...
szymonsta Posted November 3, 2012 Share Posted November 3, 2012 interesting to read.that works out to 220kw @ wheels by my calculations. for comparison, my HKS GTsupercharge'd V35 makes 234kw @ wheels at 7psi max boost. so, basically similar results whether you go turbo or supercharged in terms of peak power. i wonder how the power deliveries would compare? what injectors are you running currently? i suspect your setup will be able to produce more peak power once you sort out the tuning/injectors and whatnot. i guess depends how much boost you want to push taking into account reliability.. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6607892 Share on other sites More sharing options...
spartacus77 Posted November 3, 2012 Author Share Posted November 3, 2012 its actually 237rwkw but whos counting. stock injectors at the moment so im not gonna up the boost until i get bigger ones. im making roughly 18hp for every pound of boost i add but ill sit on it for a while. the kit was making 270kw@ wheels @9psi on the z it came off but that was a 6m/t Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6608010 Share on other sites More sharing options...
Jetwreck Posted November 3, 2012 Share Posted November 3, 2012 IMO the supercharger is the better setup for a standard motor. If you we're to do internals turbo for the winz. Driven both btw.....and done the installs on both. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6608067 Share on other sites More sharing options...
spartacus77 Posted November 4, 2012 Author Share Posted November 4, 2012 each to his own i guess i like the fact i can change boost whenever i want and that noone over here has a turbo v (that i know of) while there are a few s/c on Vs and Zs plus that turbo does whistle nicely Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6608391 Share on other sites More sharing options...
Bourbon Boy Posted November 7, 2012 Share Posted November 7, 2012 Hey can you tell me how much it cost you all together including the tune? Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6613142 Share on other sites More sharing options...
spartacus77 Posted November 7, 2012 Author Share Posted November 7, 2012 yeah mate start to finish cost me 5500 Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6614043 Share on other sites More sharing options...
spartacus77 Posted November 10, 2012 Author Share Posted November 10, 2012 better copies of power run Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6619247 Share on other sites More sharing options...
spartacus77 Posted November 22, 2012 Author Share Posted November 22, 2012 hi all car is runnin sweet apart from a couple of little issues 1 : cel,slip,and vdc lights wont turn off i think its because the megasquirt runs the injectors now so gonna wire in some resistors to factory ecu to trick it. tried manual reset but that works until i turn car off again then lights come back once i restart. annoying! 2 : installed an Apexi turbo timer cos its a lazy mans tool so it suits me fine,but,it only seems to work if i drive a short distance. any more than 5kms it wont turn on. is there i setting i can adjust or just swap it for another? also annoying! 1000cc injectors for xmas then a run a 8psi cheers Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6636201 Share on other sites More sharing options...
PN-Mad Posted November 22, 2012 Share Posted November 22, 2012 1: go and read the error codes and hope to hell they are not for Knock. That will tell you where to go- could be for too rich/ too lean, or misfire, or CAS AFM etc etc. 2: Useless Turbo timer is useless. Turbo is water cooled. As long as you not coming off a racetrack and turning it straight off, there is no point. Easiest thing to go - just don't flog it for the last 5 mins of your journey. Rip it out and sell it to some other bloke. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6636354 Share on other sites More sharing options...
spartacus77 Posted November 22, 2012 Author Share Posted November 22, 2012 only 1 code comes up i think it was P350 cant find much about it Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6636486 Share on other sites More sharing options...
iamhe77 Posted November 22, 2012 Share Posted November 22, 2012 http://engine-codes.com/p0350_nissan.html Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6637158 Share on other sites More sharing options...
szymonsta Posted November 29, 2012 Share Posted November 29, 2012 i also have CEL permanently on - dynoe'd it to make sure no knock/leaning etc when I purchased the car and all good. i cant remember the error code, but i beleive it is to do with the oxygen sensors in the cats - they are very sensitive and as soon as one reads a value outside the normal range (which happens all the time running supercharger with aftermarket ecu,larger injectors, etc) it activates the CEL. i have also been told this by an official HKS approved worshops in australia who have seen this commonly on super- and turbo-charged VQ's. not sure what the deal with your slip and vdc lights though.. Link to comment https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/page/4/#findComment-6648704 Share on other sites More sharing options...
