PIARC are running sprints at PI, 1st & 2nd September regs are here http://www.piarc.com...es/24526S_2.pdf
Noise=95dB limit
This is not an SAU round but still thinking of heading down for the Sunday.
$240 or $210 before 25th, includes Dorian timing. Believe you can enter on day, if spots available.
Instructors are available if you wish to enter the slightly cheaper practice day Saturday – no timing.
  • Replies 49
Posted Images
keen to hit up the island again
Know what you mean. Wet Sandown highlighted issues with my set up and PI was last dry event so looking forward to going back and playing with setup. Popped in to south Melbourne Pedders at the weekend, alignment was out of whack unfortunately they maxed out rear camber adjustment and it was still not enough. Looks like I'm up for more coin for adjustable rear camber arms etc to get rid of excess rear camber.
What changed? Did you bang it into something?
think he had stock ones.
To true. Nothing happened, been slack, haven't had alignment this year, had drifted significantly and inconsistent. Though I'm still over -3deg at the rear and can do nothing about it till I get aftermarket adjustable arms.
I just filled in the forms, keen to hit up the island again and break into the 2 minute lap time. Get your entries in soon and save $30 before the 25th. :)
did you enter for sat or suday?
My entry was confirmed by email yesterday too, as scrutiny opens at 7:30 I guess we would need to be there around that time, especially with up to 140 entrants.
I will be meeting other drivers at McDonalds Cranbourne at 6am if you want to get a quick bite and head down with us.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
