PIARC are running sprints at PI, 1st & 2nd September regs are here http://www.piarc.com...es/24526S_2.pdf
Noise=95dB limit
This is not an SAU round but still thinking of heading down for the Sunday.
$240 or $210 before 25th, includes Dorian timing. Believe you can enter on day, if spots available.
Instructors are available if you wish to enter the slightly cheaper practice day Saturday – no timing.
  • Replies 49
Posted Images
keen to hit up the island again
Know what you mean. Wet Sandown highlighted issues with my set up and PI was last dry event so looking forward to going back and playing with setup. Popped in to south Melbourne Pedders at the weekend, alignment was out of whack unfortunately they maxed out rear camber adjustment and it was still not enough. Looks like I'm up for more coin for adjustable rear camber arms etc to get rid of excess rear camber.
What changed? Did you bang it into something?
think he had stock ones.
To true. Nothing happened, been slack, haven't had alignment this year, had drifted significantly and inconsistent. Though I'm still over -3deg at the rear and can do nothing about it till I get aftermarket adjustable arms.
I just filled in the forms, keen to hit up the island again and break into the 2 minute lap time. Get your entries in soon and save $30 before the 25th. :)
did you enter for sat or suday?
My entry was confirmed by email yesterday too, as scrutiny opens at 7:30 I guess we would need to be there around that time, especially with up to 140 entrants.
I will be meeting other drivers at McDonalds Cranbourne at 6am if you want to get a quick bite and head down with us.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
