I tend to leave from Northcote at 5:45am, though I don't stop on the way. Note I don't go through Cranbourne either - I head towards Pakenham on the Freeway and cut down Koo Wee Rup Road.
Went down to Chasers to have the engine checked out, don't know if the other garage's instrument read low last time but compression was again even but up at around 160 per cylinder, leak down test was also very good. Looks like I can continue to target my money at the rear suspension and possibly Paul Ruzic EM Pro to provide engine monitoring to keep it so - currently just have standard dash.
  • Replies 49
Posted Images
good news on the comp test, just keep it cool and fill it with fresh oil frequently and bobs your uncle!
i'd love to throw some money at the rear end in my car, it's a constant struggle trying to keep it straight.
have fun at the island!
putting 300kw through my stock rear end was a nightmare at Sandown I just couldnt get on it anywhere but the straights, even then it was point and shoot but dont pull the trigger to hard
...wasnt too bad at PI though, just drove like a normal car but faster,only on the tight tight handers it wanted to step out :D
1.5Way KAAZ or NISMO diff is a must. it's $1500 worth of kit, but money well spent.
This is what Birds was telling me.
How much of a difference did you notice? Just traction out of corners or....?
Yeah diff and brakes is the last big spend I have really..It will have to wait though so in the meantime I will just cruise around and learn the road..
And swaybars..mind of I ask what sizes you run John or is it secret squirrel business..
Adjustable Whiteline Front, there is only one size 24mm.
Fixed Whitline Rear, 20mm.
The diff changes the way the car behaves, not only under power but off power into corners. It's less sloppy and more direct, the change on the road is equally as good. Rob in the black 33 just changed from the stock diff to a KAAZ 1.5 way recently.
GTR is different. The GTR rear subframe is different so is the front (obvious reasons there, front diff)
27mm for the front of the ECR33 is fixed mate. That would be terrible, unless you like massive understeer all the time.
My entry was confirmed by email yesterday too, as scrutiny opens at 7:30 I guess we would need to be there around that time, especially with up to 140 entrants.
I will be meeting other drivers at McDonalds Cranbourne at 6am if you want to get a quick bite and head down with us.
cool, i'll try to make it by then however i'll probably be running late and miss you guys.
What a gorgeous day, looking forward to tomorrow. Where are you planning to park up, if early, close to cafe or at far end of garages near the garage used as the entrance to pit lane?
^^ Was pushed up beside the scrutineering shed, didn't look good.
Pretty happy with my new PB of 1:56, not bad for a 2 ton car I thought. lol.
My gearbox let me down again, perhaps time for a manual conversion?
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
