Ive been told by to places now that after fitting an aftermarket stereo to my m35 axis that the trip screen will not work Is this true?. In my eyes I cant see this, surley it runs of the ecu not the stereo, think im going to get the aftermarket fascia & do it myself
Any insight would be great.
https://www.sau.com.au/forums/topic/407121-is-this-true/
No, not true.
I think it is the A/C that is on the same board as the OEM stereo which is why if the stereo stuffs up the A/C will go crazy... or so I have heard.
The pop up screen dies if you replace the DVD ROM above the glove box.
Edited by iamhe77
https://www.sau.com.au/forums/topic/407121-is-this-true/#findComment-6489637
No, not true.
Cam is correct.
The dvd rom is what controls the screen, the only integration it has with the stereo is the tv... But it doesn't play a part in the function of the screen
https://www.sau.com.au/forums/topic/407121-is-this-true/#findComment-6489856
Cam is correct.
I have an aftermarket DVD in the glovebox TV and nav still works normal before and after.
Cong from Japlink installed that for me
https://www.sau.com.au/forums/topic/407121-is-this-true/#findComment-6491043
Kool so basically if evrything goes to plan with doing it myself the screen should still work. Bought 2 nissan harnesses 1 with 1 plug & 1 with 2 plugs does it need an iso? have 3 of them just in case, for alpine 2 din.
Just hope im not bighting off more than i can chew with this lol. Dont want to fuc it.
I should be okay if I can the GTR gauges & cut out the perspex holes without cracking it should all go to plan.
https://www.sau.com.au/forums/topic/407121-is-this-true/#findComment-6491338
So if I was going to getz the English conversion after installation of the stereo it wont work? the translation that is.
The translation needs the DVD ROM above the glovebox.
Nothing to do with the stereo
https://www.sau.com.au/forums/topic/407121-is-this-true/#findComment-6491727
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
