After looking into R34 GTR's and their upgrade paths, i was wondering what people do as far as engine management goes. That monitor that sits in the dash i assume hooks up to the standard computer, so if you replace the stock computer with an aftermarket one does it mean you lose all function of that display? What are the options to keep the full functionality of the display unit but also allow much better tunability of an aftermarket ECU?
Just wondering what you R34 GTR owners have done...
Cheers,
Andrew
https://www.sau.com.au/forums/topic/40714-r34-gtr-engine-management-options/
No you are both confused.
The monitor that sits on the dash is just a large range of electronic clusters if you like. All they have in it is readings of various factors such as exhaust temps, boost, battery voltage etc. There seems to be a lot of stuff but there isnt really. The only thing you can change through that system is the "redline" values. EG if you want the little red warning light to come on when your oil temp hits 120deg you can set it to that value. But nothing to actually CONTROL any values.
The aftermarket ecu has nothing to do with it. I run a power fc on my r34 gtr btw. It did previously have a mines ecu. There are no limiting options with them.
As for the boost controller simon - there isnt one. Again all you can do is set the redline factor again. the max level the standard little computer goes up to is 1.2bar.
If you want to further that there is a Nismo aftersales option which has increased the boost screen to 2.0bar - also contains things like the g-force meter and lap times you see on those english GTR dvd's.
Hope that clears things up.
:P
aaahh... sweet. So the screen is it's own computer that gets the readings from various sensors rather than from the ecu itself (which would get them from other sensors). So if you pull out the stock ecu the monitor will still be able to display the items as normal. The nismo aftersales option, is that just a display upgrade? So if i got a powerfc and the nismo aftersales option i could see 1.8bar on the screen? Or is the aftersales option only available if you keep the stock ECU?
Thanks for the info
Andrew
The best thing you can do is think of them as completely seperate entities. You can get the nismo upgrade for the display until and it has no consequence over the ecu what so ever. As I said all it is is a set of electronic display clusters. There is basically 3 different screens. One shows you ALL of the elements in a simple line format - this looks unexciting but eventually this is the screen you will use the most. Secondly there is a screen where you can chose any 2 parameters and it will show them in a dial format and record the highest peak for that run, and finally there is a screen where you can chose one parameter and next to it there will be a graph plotted of the results against time. This looks cool but Id rather be able to see everything at once.
As far as getting the nismo upgrade well IMO you really have to be made of money to get it. All its really going to do is allow you to read up to 2.0bar on your boost on this screen. However - chances are that if you are going to be putting in aftermarket turbo's you will have some form of EBC that will be telling you your boost anyways so spending the $1,000 on the nismo screen upgrade seems extreme to me.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
