Engine sitting awaiting its head to be sent off for porting and block/internal inspection.
I was told by the previous owner that the car had an ATI balancer turns out this was a lie not happy.
Edited by Tyranus
Ati balancers are very visible so it's fairly easy to check if they are there...
Regardless, you can buy one from the states for around $600 delivered
Well to be honest i was a GT-R noob who only knew the basics.. i have much more knowledge now. I have already purchased an 1000hp ATI balancer which is on its way.
Edited by Tyranus
true, but to be told something from the previous owner that is just a straight up lie isn't much fun.
True that. Especially after he says im the "X SAU President of SA, i dont take short cuts..". Oh well shit happens at the end of the day i still got my self a very good car for the price i paid for it.
so your going the 2.7 stroker, that is still the only one they make for the 26 isn't it?
Epic power will result, i really think you are being a little modest looking to make 500kw with an SPL, when that is achievable with the KAI. Great looking 32 you have
Looks like a crazy build, good luck, cant wait to see it finished, will be keeping an eye on this thing
Cheers mate, i cant wait for it. I miss driving thig so much i cant put it into words lol.
Well ive been offered to be a test car for Nitto's new 2.8 stroker kit so im weighing up my options. Im trying to not over hype myself with a huge power figure goal lol. But yeah 500+ ON ALL FOUR not rwkw is the goal. And thanks for the compliment.
  • 4 months later...
Good news: I got myself a Nitto 2.8 stroker kit + N1 Block.
Bad news: Shane aka RBWARE is a lier.
Im very disapointed and angry right now Shane aka RBWARE.
When you sold me this car you advertised it with the following modifications.
ENGINE
Forged pistons and HKS Cams
Complete re-built head w/copper head gasket
Motor balanced, blueprinted and crank tested
Baffled sump
Upom inspecting the block before the sale we see that the following are stock standard.
Standard Rods
Standard Rod Nuts and Studs
Standard Main Studs
Standard Head Studs
Standard Cams
The block has not been balanced the heads have not been rebuilt.
I purchased the car under the impression that it was fully built. I wanted to resolve this privately but RBWARE has blocked me for some reason unknown to me. So mate send me a PM. Cause you have to answer to me.
Edited by Tyranus
Oooohhhhh that is so f@rked up!!!!
So disappointing hearings things like that.
I like your build 500kw at all fours is insane!
Despite all the bullsh!t you went / going through, I hope you keep going with what you want.
Edited by Ants
Cheers mate. Yea it is quiet dissapointing seeing that the previous owber was the former SAU presidebt for SA. Also boasting about how ge doesbt take shortcuts..
Anyway my build is still on. The target is minimum 500awkw we are aiming for 1000hp at the engine. So im not sure if should go full 5 or 4 inch exhaust. I will post pics as soon as the kit and bloxk arrives.
You can't blame your self, it wasn't exactly a random seller. Being a president clearly gave him some credibility, all he did was put a big dent in everyone's trust. It was/is a nice car there was no need to false advertise, engine is healthy and would be perfectly fine for 90% of people's use. However this obviously could have ended REALLY bad!!! cant wait to see this thing on the road!!! Keep the progresss flowing mate
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
