  • 4 weeks later...
Myself and EDGE Motorworks will like to send our thanks to Pete and to the rest of the Hypertune crew for there amazing work. The quality of the welds is amazing, cant wait to slap this thing onto my head!
My Hypertune V2 Plenum arrived today along with a 90mm TB and twin entry billet fuel rail.
My Hypertune FMIC is to arrive next week.
goddam that plenum is a master piece !!
how much power are you aiming to run?
The aim of the build was 1000HP so trying to crack that or to get as close to it as possible. Realistically though if everything goes well i should make well over 600awkw.
Edited by Tyranus
Hi Sedat, i dont know if Barry metioned to you, i was over there a few Saturdyas ago to compare our head to a few of his race heads and we laid yours out on the table as it was the best ported there to look at and compared to mine.
I spent 8 to 10 hours the weekend before working on 1 exhaust port (i use to port a lot of heads between the late 70's to early 80's before Stefan was born and i had to put the die grider away and actually work for a living), taking my time, studying the casting and port shape getting it to 95% of where i wanted it, i had not done the other 5 so it was time for me to sit down and look at some others professionally done and take some detailed measurements, study them and to see if my theory/direction was wrong or right.
End conclusion is our exhaust ports are virtually identical, most areas are indentical to the exact 0.01mm in size, i have a few areas that are no more than 0.5mm larger (nothing), my flange outlet is around 1mm larger (you have a reversion step from the head to mainifold join which is good, my gas reversion step im building into the 6boost manifold which explains the 1mm port outlet diffrence) , i took a different approch (slightly) on the short side radius near the valve, i pushed our exhaust divider wall back 2mm more as i felt there was a restriction there which is a minor diffrence, i could be wrong that it was a restriction, my ideas VS a professional porters.
All i can say is your head was very, very well done.
Looking at what it cost to get yours done and the time im putting into ours, im questioning if its just wiser to hand it to Brendan to get done and just sit back and enjoy life. ;)
Our combustion chamber shape will be different to yours (spoke to Brendan about it last time i was there and he said its something that could work out surprising for E85 but its untested on a RB), looks like i will be the guinea pig with the idea.
They did a great job on that head, you will do well with it....should push out some great numbers....
Whats this i heard from Barry that you and a mate almost knocked out the 6 foot something window guy a few doors down after he mouthed off? I heard he ran off inside to hide like a little bitch when you 2 went over. :D
Good because a few weeks earlier i also had a run in with him.
Edit, forgot to mention, you will need to wipe down that inlet mainifold, i was drooling all over it, its a work of art, take lots of pics of the inside, once its on you wont get to see the craftmanship inside again.
Edited by GTRPSI
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
