  On 07/02/2015 at 7:23 AM, GTRPSI said:
Brendans got a shit load of machining and hand work in front of him now.
Its in good hands from here on......
Indeed, He looked very comfortable and calm so i have no doubt that will he do an amazing job as per usual.
  • 1 month later...
  On 08/04/2015 at 9:54 AM, GTRPSI said:
LOL, nice.
Dont forget to hand it to Brendan so he can machine it and the RB30 block to make it fit, and re loctite all the phillips heads screws on the backing plate. :)
Hey Pete, i swung past Brendo's today he was already aware of the loctite stuff im assuming you passed on that knowledge to him.
Edited by Tyranus
Yeah, was in the shit i gave you to pass onto him, im more worried that he may have overlooked it between all the info so i thought id mention it for you to remind him.
From 2 new Tomie pumps ive had, both had 1 or 2 loose screws (not tightened like the others) and 2-3 screws without loctite from the factory.
Loose screws = coverplate leaks oil pressure......bye bye engine.....very important to check.
Edited by GTRPSI
  • Like 1
  • 1 month later...
Hey Sedat was going to call you the other day.
Have you seen this? PT7675 Gen 2 about to be released?
http://www.maperformance.com/precision-turbo-gen2-pt7675-cea-turbocharger.html
Note the list of new turbos on the bottom.
Told you to hold back and wait.......lots of new goodies being released. :)
  • Like 1
Hey Pete since we last spoke i was set on getting a 7675 gt42 but i deciced to wait.. listen to your elders as wogs always say and im glad that i did.
Ill be waiting for more info to become available on the pt2 7685.
Edited by Tyranus
  • Like 1
Yeah just kick it man, wait for the engine to be built, your other business priorities come first, till its ready who knows what the latest and results are going to be.
Was showing it to Stefan the other night as he is about to order some other stuff from the US for his S2000 and was going to order the turbo he wanted at the same time, now he says what you just said, leave it for last. (Finally he is listening)
And im currently working hard on convincing him NOT to go precision. (Long story, we will talk about it next time we catch up)
  • Like 1
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
