  • Replies 55
I prefer 255/35 on a 9.5.
I'm old so stretch doesn't appeal to me but hey if thats the new craze I'm fine with that too but not on my car.
I'm not sure of the effect on the tyre wall, if any
Yeah thats a good size (what I have in RS-R format though so more a 265).
If you go with too much stretch, you end up wearing out your sidewalls pretty quickly.
Cheers guys.
Ain't being a tight arse otherwise I would be driving on cheap shit tyres. I like it, it's the look I was going for and it has a more direct road feel. This is my family daily so I don't need 265/35 RS-R's or equivalent. Also I don't have room to run a wider tyre unless i raise it up due to the poor coilover clearance in the rear because of the cargo area.
Alligators gon' alligate
Wearing them out? What's your reasoning behind this statement?
Talking extreme hellaflush spec... :) When running -5deg camber + say a 225 on a 9.5" rim, you actually wear out the sidewall really quickly as you're rolling on it to an extent. Anyway, It's all g, have it how you want, I prefer fat tyres :)
I thought you ment under normal fitment. There's clips of VIP spec cars with almost 10 deg camber with sparks flying off the rims cos there not enough tread
I know for a fact the Michelin PS3's 235/40 R18 will fit perfectly on a 9.5 inch rim, but that is the only 235 that would fit. It changes from brand to brand and even from style to style inside brands.
And GTRKat is right when it comes to Costco tyres, they are cheap Bridgestones/Michelins in small, and common performance sizes but not in the bigger stuff.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
