Had a misfiring problem - took it to local mechanic who replaced one coil pack and the car was running well for 1 day then misfire returned. I used one of the diy tutorials to replace all coil packs. car ran fine for approx 40kms then started misfiring again - nowhere near as bad as they were misfiring before I changed all the coil packs but misfiring nonetheless.What could be causing this?? Anybody?
No, did not change plugs - they were all replaced about 7 months ago....(am checking them all today, though)
I went a bit cheap on the coil packs - FUJI Ultra sparks (sold by osaka.co.nz) ($345 for all six)
as above, weak coils prob fouled old plugs, just change them, haven't heard of those coils, maybe they're getting weak already, go for .8 plugs
(this isn't forced induction performance related haha)
Edited by WMDC35
Plugs are most likely covered in shit from driving around with f**ked coilpacks. Change them.
If your mechanic changed one coilpack, I would never go back there again. Unless you told him to quick-fix it and change one.
Its like buying one new tyre, or replacing one big end bearing, or one brake pad. Just stupid.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
