Most bov's are open at cruise due to the vacuum, unless they have the stiff spring fitted.
I would have said so for OEM recirculating BOVs, but not for aftermarket ones. More to the point, when you are at cruise with some manifold vacuum, an open atmo BOV will actually cause lean running because it's an inward air leak. And if you are on boost, then it won't have vacuum on it so it won't be open.
  • Replies 71
I have seen it many times with the Turbosmart race Vband bov's, they are shipped with a soft spring and you need to replace it with a stiffer one. Probably just another way for turbosmart to make some more money out of you. I have the Turbosmart Kompact on mine and it had the same problem.
Ron,
A nearly stock R34 that gives fuel economy that bad and isn't being thrashed around hard ALL the time does not need a tune. It needs whatever the problem is fixed.
My Neo is about the same as yours and I can easily get >400 km/tank. In fact, the last 4 tanks have been about 12.5 l/100km, and the 4 tanks before that (before it got quite as cold) were all <12. I expect that to get better once I tune it, although the extra boost will probably cost me in tyre smoke. Nevertheless, my economy is as bad as it is because the majority of my miles are start stop rush hour traffic. So I cannot believe that there's any good reason (apart from a sensor type problem) for your car to use as much juice as it does, and I definitely do not believe you cam make it go from where it is now, to decent-good fuel economy by tuning it. You will only likely be able to get it from where it is to merely terrible.
GTSBoy I dont think you know that my car is already running Nistune and is tuned at 13psi on the stock turbo (yes I know how lame is that), hence the reason for me being pretty sure its a tune problem, another reason I think its the damn tune is because it pulls timing / groans or something under hard throttle stabs and theres no power for 2-3 secs before it goes. But if I gently apply the throttle then it does go hard like it should, very different to a hard stab. Its well serviced and running good plugs coils filters oil O2 sensor etc, maybe the coolant temp sensor needs a look aswl..?
So yeah waiting on my wastegate from the US n ordering new turbo soon then its a install n full tune and hoping it will be da bomb..
Yeah, I figured you'd had it tuned....but on the assumption that Jez tuned it, I wouldn't have thought it was tuned in a crap way, and it if doesn't behave well with Nistune running the show, it's hard to see how it can be made better with another tune. You'd expect that when it was tuned, the mixtures were reasonable and the timing looked sensible. If it is now crappy, then something has since gone wrong, yes?
By the way, I don't think 13psi on the stock turbo is lame. I have the stock turbo on my Neo and don't even have the factory boost solenoid, so I'm only getting 5 psi at the moment. I think the car drives well, and I look forward to when I get it through Regency so I can refit my boost controller and wind it up and tune it at 12 psi or so. 200 - 210 rwkW is plenty for making it (R32) a nice car to drive.
Definitely get the coolant sensor checked. They do fail. Can you hook up a consult cable/scanner/Nistune to see what the ECU thinks the temperature is when the engine is all warmed up? I'd expect it to think it's <60°C by the fuel usage you report.
Unfortunately dont have Nistune software and the consult cable, so cant diagnose the ecu. When I got the car it was running better economy though not by much, I added bits like exhaust, fuel pump, ecu, fmic and then got it tuned, after the tune the economy didnt go better as I thought it should, it actually went down to what it is now but I didnt think much of it then as I was very new to Skylines and thought thats how it would be, now that Im familiar and see others getting 400-450kms to a tank, Im getting pretty frustrated lol. After all the servicing and adding new parts n filters, O2 sensor etc, its still the same, it could also be a coolant temp sensor or a vacuum leak maybe, which wasnt checked during the tune. Not sure if a vacuum leak or coolant sensor could worsen economy THAT much, though. So that doesnt leave much else to pinpoint I guess. AFM, CAS? I think these are ok.
I currently have 187rwkw and think its very lame after going for a ride in a 336rwkw demon thanks to Mick O haha. 2nd gear and a bit of 3rd is actually nice at this power level- 200rwkw..
Ron bring me ur car and i will gladly check it out for free :)
Even the Ethanol cars i tune get alot better economy than urs.
But i have seen how u drive :P
And remember u had a stock dump pipe at the time of tune too which definately didnt help.
Have u upgraded it yet?
Have u replaced the 02 sensor? I have replaced an 02 sensor on a r33. Went from 300km to 450km economy.
Also may need to do a smoke test to be sure
Anyone with bad fuel economy in an R33...replace your O2 sensor if it hasn't been done in the last ~30,000km. They are seldom replaced in these cars, people just don't think of it as a normal servicing requirement. But when they shit themselves they cost you ~70-80km a tank and being located in the exhaust system, faults can be synonymous with exhaust changes or tunes that produce hotter EGTs. Have fixed many R33s by replacing the O2. It is a <$100 part and the first place I'd look if I had bad economy.
Thanks for the offer Jez, thats nice of you, yes I know that stock dump was a big power restriction as you said before and yes I changed it longtime ago with a jjr bellmouth AND a new O2 sensor. It boosts quicker and harder and I can feel a good midrange chunk just from that dump alone.. :) The economy however remained unchanged and I wouldnt be surprised if I was driving one of the most uneconomical cars in Australia :( I am slowly replacing a few bits of vac hoses here n there now with repco and supercheap crap? hoses just for peace of mind from vac leaks..
Ok so it sounds like the cold start may be too rich.
Is it stop start traffic?
It is sort of, what can I say, 5 traffic lights and bit of a crawl here and there, 3-4 roundabouts, Sydney has no room to enjoy your car, no peace... Dont know if the cold start could make such a huge difference to the fuel haha.. Maybe I need to have a look at my coolant temp sensor..
If I can get 12.5L/100km with a GT3076/GT3040 turbos around Sydney then you are either the biggest lead foot in history or there is an issue with the car.
Sydney roads and 1 point left on my licence doesnt allow me to be a lead foot haha -- definitely a car issue.. :D
Did u only get 1 point after getting ur licence back? Or did u lose more since?
I lost 12 points on one go on a double demerit weekend (normally 6), so have one left now.. Nice aye :unsure:
You dont get any points back till 3 years from the date of offence regardless of when you get your licence back..sad.
Edited by rondofj
In the last 15 years I've lost 3 points, all of which were last November, not long after I got my first Skyline :whistling:
Hahaha
Im the opposite. I normally lose points in a shitbox. Has been a while tho
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
