Hey guys I'm taking my car to the tuners again in the near future and need some advice on what to run psi wise through my wastegate and ebc so I can buy some springs. I've been told to get springs for the wastegate that would be 4-5psi less than what I'll run the ebc at when I want higher boost. What boost would be suggested for my setup ??
Just an update on what I will be running;
Current r33 rb25det unopened.
Bosch intank 040
adjustable BOV
BP Ultimate
POD
Power FC
3inch exhaust (dump/front/decat) - 3.5 decat back to cannon
FMIC
Greddy Plenum
GT3076r .82a/r
Turbosmart 50mm Progate
Fuel rail to suit top feed injectors
siemen 700cc injectors
Z32 AFM with tomie plug
6boost highmount manifold
EBC - Greddy profec II
Snow performance water/meth injection
Tomie cams
Cam gears
Gaskets -intake and exhaust
Fuel reg
Splitfire coilpacks
Catch can
Water/oil lines for turbo
New dump pipe and wastegate dump to suit
Think that's about it. Any help is appreciated.
Cheers
https://www.sau.com.au/forums/topic/407258-recommended-boost-pressure/
I see a big list of parts, but I don't see your goals or what you'll be happy with?
The usual answer to that question is As much power as I can run safely.
In which case, you take it to the tuner and see how it goes.
I'll bite and throw out a figure of about 19/20psi high boost. So get the wastegate acuator set at 15 or 16psi so you don't need to bleed off too much with an EBC.
9000 :P
Your running water/meth so push it and see what it likes, on 98 I run 18-16 psi which is 311kw but with E85 (assuming WMI is similar) I run 21-18 psi ad run 357kw, this is a stock RB25.... So see what your tuner is happy with..... Oh and the gate spring is 1 bar.....
9000 :P
Beat me to it :(
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
