Had a misfiring problem - took it to local mechanic who replaced one coil pack and the car was running well for 1 day then misfire returned. I used one of the diy tutorials to replace all coil packs. car ran fine for approx 40kms then started misfiring again - nowhere near as bad as they were misfiring before I changed all the coil packs but misfiring nonetheless.What could be causing this?
Spark plugs had been changed 7 months ago.
also noticed that the two coil packs had different numbers on - 4 of them are numbered 543, 1 is 791 and another 8X5. they all have HANSHIN MCP1440 on the back of em except the one numbered 791 has MCP1340. Does this mean anything?
All coil packs in there now are brand new ones FUJI ULTRA SPARK - sold by www.OSAKA.co.nz.
As you've probably gathered, I am a newbie. Help please!
First time I've heard of these coilpacks, and I've heard of them all (JJR, super spark, yellow jackets, OEM, splitfire, okada project plasma etc).
Which brand and what model spark plugs were used (NGK copper, NGK iridium etc) and the exact model number of them (gap and heat range too). If they are copper spark plugs then they are in all likelyhood due to be changed depending how far have you travelled in those 7 months?
Change the spark plug gap to 0.8mm and see if that helps and take a picture of them all while they're out, so we can see what kinda shape they're in. If it doesn't solve the misfire, then put new plugs in. If that still doesn't solve it then unplug individual coilpacks to work out which cylinder is the one misfiring and put a known working one in it's place, if the misfire is gone then replace that faulty coilpack (should be under warranty)
The plugs are all NGK Iridiums
I pulled all plugs off and they all seem in very good nick. The first one had relatively more soot buildup then the other five and was also a bit wet. there was a bit of liquid around the spark plug in the well. The coil on this first plug seems faulty - the collar actually moves back and forth a bit and there is a small white streak on the black silicone(?). this is one of the new Fuji coils I put in Thursday.
I replaced the faulty coil pack with one from the old set and it seems to have worked - No more misfires. Hopefully the misfiring is gone for good this time.
Fuji Ultra Coil Packs are made in Japan apparently. they have a red jacket on them. Yeah, $345 is pretty cheap for coil packs....
Thanks for your help guys. much appreciated.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
