Hey everyone,
Well the time has come for me to choose which water pump to put on my freshly forged RB25 NEO.
I know there are many threads of stock vs N1 water pumps but I'm asking for your opinion for my specific setup.
I have an N1 and NEO pump to choose from. The NEO pump is not like a standard RB25 pump, the casting is different. It looks like Nissan tried to rectify an issue on the NEO with this pump.
The car is a 95% dedicated track car for sprinting. Rev limit will be no higher than 7,500RPM. I'll be using an OEM R31 radiator, but of I'm having over heating issues I'll throw in a PWR rad.
My understanding is the N1 is really designed for engines seeing very high RPM above 8,000 RPM regularly. Now my engine will spend a lot of time revving high, but not that high.
The downsides of fitting an N1 pump is the elongated hole may leak and it may not pump enough water at low RPM.
What do you guys think?
I'll upload a pic comparing the two when I'm on my computer.
Cheers.
https://www.sau.com.au/forums/topic/407301-which-water-pump/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
