Cut Out At 5500 Rpm In 5Th And About 7000 In 4Th. No Speed Sensor ?
Hey everybody just completed my rb25 box conversion in my rb25ed 32 4 door. Now my problem is at 5500rpm in fifth it feels like i hit a wall. It will not go any where past 5500, And im pretty sure its only WOT that it does it. Someone suggested speed limiter. Sounds logical BUT i dont have the cable hooked up ? The reason it doesnt make sense is it will bounce the limiter in the third but 4th hits the wall at around 7000 and 5th hits at 5500. I dont think its fuel as it has a good bosh 040 pump and here it whizzing and all other gears are fine. Now this problem has only just happened after the box. Therefore thats why im thinking maybe some sort of limiter is in place because of it. Related mods that may help find the problem are as follows
-FMIC
-Plugs were changed about 1000k ago
-Nistuned r32 ecu
-Bosch 040
-Apexi pod in a box
-3' straight through exhaust
-34 turbo at around 10 psi
Someone suggested just give the yellow wire the snip (53) and try but would prefer to know if anyone has ever had any experiences like this.
it could just be the speed cut, but i'd have thought that 5500rpm in 5th is above 180kmh. i'd say that you are just not making enough power to overcome the drag. you'll need a lot more power to get to redline in 5th gear. when i still had access to the runway at the local airport my r33 topped out at about 6500rpm.
but if you are getting a lower rev limit in 4th as well, then it's speed cut. my old 180sx hit the speed cut on the dyno at 7000rpm (500rpm below the rev limit)
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
