Item: 15 Row Oil Cooler w/ FULL Oil Filter Relocation Kit
Features:
- Keeps engine components at correct running temperature
- 15 row GReddy style oil cooler
- 290x205x50mm with a mega 600cm cooling area (front and sides)
- (-10AN) Male fittings size
- Oil cooler made of aluminium and coated with an anti-corrosive
- Full engine oil filter relocation kit
- Accepts all spin-on M20X1.5 thread size oil filters
- Sandwich plate includes ports for 2 extra gauges
- Comes with all nuts bolts and brackets
- 3 Earls type braided stainless steel flexi oil lines (125, 145 and 165cm)
- Practically a stand alone setup - easy installation!
Has been extensively used on all Nissan RB series engines
$345 including Delivery & Insurance SAU SPECIAL - FREE POSTAGE
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
CUSTOMER INSTALLS - Send us yours next!
Ordered directly... what a great value kit!
haha good stuff :yes: and it's already been sent!
We specialise in great value guys.
  • 2 months later...
Can personally vouch for these kits and Brendan's exceptional customer service. Bought a 15 row kit and extra line 8 months ago, fitted that along with a Greddy relocation plate with thermostat, been on the car for 6+ months, no leaks, no problems! I don't have an oil temp gauge, but noticed a solid drop/better maintained coolant temps during hard driving, and my oil pressure doesn't drop as low as it used to on 35 degree days. Will try to get some photos up of my install tonight. :thumbsup:
How hard was it to install? Did you do it yourself mate?
The kit itself is relatively easy, but the areas you need to access are a pain in the ass and i'm a mechanic by trade which always helps.... A good arvo in the shed with basic tools and experience would be fine.
can you fit it for me?
Hi,
We don't do installation's at this point in time, we reccomend professional installation with all our universal kit's.
- Brendan
  • 1 year later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 months later...
Down to $300 for the lot!
Simply re-position your old filter and hook up the braided lines.
Oil cooler includes mounting brackets.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
