Hi guys, today i was driving on the motorway and out of nowhere my ceffy starts sounding like a wrx?! i was like 1km away from the inlaws so i practically rolled to their place. It would run smoothly then start misssing on and off. So i left it for a while and a couple of hours later started it and it ran fine, so i took it for a drive round the block but it seems way down on power. Any help or ideas would be great as i have to drive 2hrs home tommorow. thanks
thanks i will have a look, would this cause it to be so down on power? its weird because its never done anything like this before. Also the catch can seems to have filled up fairly fast since the last time i checked.
Turned out to be a combination of things, igniter pack plugs were corroded, the connection between coil pack and the top of the spark plugs had been arcing badly and also a coil pack has shit itself. Thanks for the help guys
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
