I don't think the factory gauge is much chop BUT even if it's half accurate I find the temp goes up after some spirited driving, this was the same at 200kw, 250kw and now at 360kw (although it hasn't had a good run at this power yet)...
I will be going a bigger Radiator and Engine oil cooler when I start tracking the car a bit more.... Possibly a steer cooler too :)
Hook up a decent gauge and keep an eye on the temp, cars react differently in different conditions so you'll soon know if its good or bad...... Ill still fit one eventually when i can afford too.
I will only track it once maybe and then a few drift days so prob wont worry about getting one. It has gauges but they aren't hooked up.
answered you own question there. Get one!!!!
Engines are designed from factory to run at an optimum oil temp. Increased power means more heat, so more oil temp.
Personally, I run an oil cooler on EVERY modified car I own and have ever owned. Better to be safe than sorry
I saw them on Facebook cheap the other night, Cartel or GKTech? Cant remember which one it was but they looksk alright for the price.... Most places have them, JJAp etc
Cartel does very good priced kits. I got this one recently really good quality piece of kit:
http://shop.cartel-aus.com/Thermostatic-Basic-Oil-Cooler-Kit-DWEB016.htm
I would add him on facebook cause he did post up a cheaper relocation oil cooler kit than the one on the page just recently. I didn't want relocation but did want a thermostat so I went with that kit
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
